Home > Technical > Automatic wipers now don't work |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
If you read the manual it tells you to move the wiper stalk up one notch. Nothing will happen until the windscreen gets wet.As i have said before do not leave it in auto mode overnight in cold and frosty weather. As soon as you turn ignition on, the wipers will try to operate.If they are frozen to windscreen they will get torn or the motor could burn out itisme |
Wed Dec 17 2014 3:58pm |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 |
I kno that but thanks.
Wed Dec 17 2014 4:05pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
You don't turn it up one notch, you move the lever up a tad In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Wed Dec 17 2014 7:02pm |
DaveB Member Since: 11 Aug 2014 Posts: 38 |
It seems odd it would just suddenly fail but I do know from a recent experience that when the sensor does fail the wipers revert to a normal delay function on the first click up. The sensitivity dial then simply adjusts the delay. As the OP says, you then have to turn them off manually as the delay function will continue to work whether the screen is wet or not.
Thu Dec 18 2014 11:55am |
