Home > Technical > Black Smoke. Turbo Pipe? Can I Put It Off? |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 |
My car has decided recently to pump out plumes of black smoke when floored or kicked down. It has always been a remarkably un-smokey car up to now. This has developed the last few weeks.
Thu Nov 27 2014 10:00pm |
Intercooler hose is usual culprit. Easily replaced It's got a split in it or its delaminated. Bodsys Brake Bible
Fri Nov 28 2014 12:39am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
A new hose is less than £40, and takes around half an hour to fit |
Fri Nov 28 2014 6:35am |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 |
i thought if you had your car mapped it kicks out soot? 2006 RRS Supercharged 4.2 HST muthuaflecka! |
Fri Nov 28 2014 9:45am |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
I had this and it turned out to be a split in the actual intercooler which had to be replaced. Changed the hoses to silicones while it was out. I'd get it checked before you go mate as your options will be more limited once you're there. |
Sun Nov 30 2014 1:50pm |
As it goes, I couldn't find anyone to look at it before we went, so I went anyway. Apart from smoke, all was well.
Wed Dec 17 2014 1:11pm |
could still be linked with Intercooler, or could be EGR valves. First port of call on the intercooler hose and see how it goes from there. Bodsys Brake Bible
Wed Dec 17 2014 1:26pm |
Thanks Bodsy. The pipe should be here in a day or two.
Wed Dec 17 2014 1:33pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Worth getting it done as you will be getting worse fuel consumption too.
Wed Dec 17 2014 1:40pm |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 |
I had the sloooooow pullaway then quick pick up a few weeks back and it was the Egr's, had them blanked and been fine since.
Wed Dec 17 2014 7:32pm |
I read about those too, but I also read that both are unlikely to fail together and if the smoke is coming out of both exhausts as well, the pipe is the more likely culprit. Actually, looking at the photo of that pipe, and the price of them, if they go so frequently, I may consider having a batch knocked up to see if they sell. |
Wed Dec 17 2014 8:39pm |
Interesting about smoke from both tailpipes. Didn't notice any on mine so i expect your right, even cheaper fix |
Wed Dec 17 2014 11:02pm |
Yes, very simple to change, more difficult to get the friggin plastic clips off the lower plastic radiator guard thing in the wheel arch than it is to change the pipe itself. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Wed Dec 17 2014 11:36pm |
Thanks again Bodsy. You are an asset to the site. |
Thu Dec 18 2014 12:17am |
