Home > Faults & Fixes > Transfer Case ECU Location |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
It's with the ECU in a box (the "E Box") on the firewall behind the battery. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 13 2014 7:16pm |
L4FLIROP Member Since: 26 Aug 2014 Location: Washington DC Posts: 19 |
What is involved to get at it ?
Thu Nov 13 2014 10:09pm |
Remove the battery and you should see the e-box. Remove the cover by releasing the clip on each side.
Thu Nov 13 2014 10:29pm |
I have been having the HDC fault changed the brake switch but also I recently power washed the engine and I have the LR Christmas tree on the Dash so that's got to be the problem |
Thu Nov 13 2014 11:24pm |
Well this really blows I cleaned contacts found some corrosion and used dioxit on the contacts after moving the corrosion. Reassembled ran my Nanocomm to clear the ECU's and now I have a Permanent ECU Failure on the Transfer case.
Fri Nov 14 2014 12:16am |
I think the ECU is Toast, I checked the fuses and the Nanocomm is unable to read the ECU info. I am wondering if an ECU will fix this or if there is other damage to the system |
Fri Nov 14 2014 2:55am |
Maybe take the ECU out again, check for bent pins and displaced terminals on the connectors and then reseat all the connectors and try it again. If still no go then there are specialists who can fix the ECU in the UK bba-reman are often recommended but maybe you have local repairers? Good luck! 2008 MY Java Black TDV8 HSE
Sat Nov 15 2014 11:09am |
Nickr6r Member Since: 28 Jun 2014 Location: Burnley Posts: 50 |
I had the same hdc fault was the transfer case ecu water corroded the connections |
Sat Dec 13 2014 11:26am |
