Home > General > Battery drains when car left unlocked
Portman Len
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Last week, my RRS HSE 2011 refused to start as the battery was flat which I thought was a little odd as my car is always garaged and is left unlocked.
I called the breakdown company who jump-started the car, and after leaving it running for a couple of hours, it has been fine for the past week. Been using the car all day without an issue, got home and left the car switched-off and unlocked on my drive for five minutes and when I returned to park it in the garage, it wouldn't start.
It appears as if when I lock the car, the car always starts again, but when I leave it unlocked, it drains super quick which clearly shouldn't be the case. Obviously the car will need to go back to the dealer, but any idea what the issue will be?
The battery shouldn't drain that quickly.
Any ideas? 2011 Range Rover Sport 3.0 TDV6 HSE
Post #441060 Fri Oct 31 2014 8:20pm
Andi
Bit here;
http://www.rrsport.co.uk/forum/topic35521....tery+drain
Post #441062 Fri Oct 31 2014 9:13pm
If you leave it unlocked then it'll never go to sleep. If it stays awake then it uses lots of battery juice. 2012 SDV6 - it's missing a couple of cylinders
Post #441069 Fri Oct 31 2014 9:37pm
gogsy1956
Mine is garaged every night, sometimes not moving for a week at a time and is never locked, never had a problem with the battery running down 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #441077 Fri Oct 31 2014 10:24pm
Portman Len
That's how mine used to be, although not as long as a week. Car is only three and a half years old, so I'd expect a battery to last a little longer than that. Always owned Jaguars before switching to Range Rover, and typically a battery would last around six years. 2011 Range Rover Sport 3.0 TDV6 HSE
Post #441078 Fri Oct 31 2014 10:30pm
Portman Len
Just spoken to my dealer, who stated that when the battery in the RRS gets low, the car never recharges it fully - just maintains it at the same level. He reckons it's unlikely that the battery should fail after three years, so suggested putting it on a trickle charge overnight with a very low amp battery charger, and see if that sorts out the problem.
He also suggested that I always lock the car when its garaged, so as the car can 'go to sleep'.
Watch this space... 2011 Range Rover Sport 3.0 TDV6 HSE
Post #441111 Sat Nov 01 2014 10:26am
Disco_Mikey
Your dealer is correct Thumbs Up
This is a "feature" of the smart charging system on the 3.0 engines.
Post #441114 Sat Nov 01 2014 11:12am
Portman Len
Latest update...
Drove over to see a different dealer this morning, who ran a diagnostic on my battery which reported that the battery needs replacing at a cost of £317!!!
In two minds now... Buy a trickle feed battery charger and see if that does the trick, or bite the bullet and buy a new battery. Apparently the new battery is an AGM battery (?) which is more reliable, but given the fact that the car is only three and a half years old, I'm tempted to call Land Rover on Monday to complain.
Ideas on a postcard please...
Thanks for all of the advice so far to date. 2011 Range Rover Sport 3.0 TDV6 HSE
Post #441116 Sat Nov 01 2014 1:01pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Whilst a battery, if the car is used normally, should last longer than 3.5 years, I doubt that any car dealer or manufacturer would do anything other that laugh at the thought that they should in some way contribute towards a replacement since they cannot know whether the battery has been mistreated or not.
Post #441117 Sat Nov 01 2014 1:49pm
whippetman
Battery
My battery on the 2011 died at 3yrs 9months
Replaced with gel type at £240 inc vat by LR Assist
Fiat 500 still on original after 5 years.....
Post #441121 Sat Nov 01 2014 2:22pm
SVR575
Mine was replaced under warranty at just over two years old ! SVR 2018 in Santorini Black.
Post #441251 Sun Nov 02 2014 5:03pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Just replaced the battery on my honda CRV- it was 13 years old and done 105k.
It hadn't even failed, I just felt sorry for it!
Needless to say I've replaced the one on the Sport!
Post #441256 Sun Nov 02 2014 6:30pm
Portman Len
Well, my faith in human kind has been restored!
Spoke with the customer relations department at Land Rover this morning, and under the circumstances, they have agreed to replace the battery FOC. Must admit that their professionalism and attention to detail was simply superb, so well done Land Rover, and thank you! 2011 Range Rover Sport 3.0 TDV6 HSE
Post #441380 Mon Nov 03 2014 3:45pm
Result. Thumbs Up
Thanks for the update, and a pat on the back for Land Rover. Bow down
Post #441381 Mon Nov 03 2014 3:47pm
