Home > Technical > Washer fluid leak in passenger footwell |
Siddharthaoke Member Since: 23 May 2014 Location: United Kingdom Posts: 19 |
Update; washer pipe has cracked as it enters the passenger compartment above the fuse box behind the dash. Dash out to replace
Thu Oct 23 2014 5:33pm |
Is there no chance you can thread a thin wire down the inside of the existing tube and pull new tube back through. You can make it easier if you lubricate the old tube as much as possible with silicon or, at a push, washing up liquid. Thoroughly lubricate the new tube. |
Thu Oct 23 2014 6:47pm |
^^^^ Failing that why not put a new section of tube through bulkhead in an accessible location (even make a new hole with grommet) and join with old tube where convenient. Disconnect the old tube, blank its ends and forget it!! |
Thu Oct 23 2014 6:52pm |
Thanks, that's a good idea. I'm Not utterly confident doing this but will mention it to my local specialist Kings langley Land Rover and see what they say. |
Thu Oct 23 2014 9:08pm |
