Home > General > Help needed: ridiculous rear rattle&squeak |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 |
Could the spare wheel be loose ? or maybe the weights that hang under the back moving around ? |
Tue Sep 23 2014 7:34pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Get the mrs to drive it while your in the back. 👍my guess is a tired ball joint if it mimics road surface changes. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Sep 23 2014 8:56pm |
Yanislav Member Since: 23 Sep 2014 Location: Sofia Posts: 4 |
I will definitely check the spare tire because the squeak sounds like something made out of rubber that moving around, I haven't thought of that and is actually a great idea. I will also check the surrounding area and see what I can find. As soon as the weather clears I will take another ride in the trunk that's for sure. Hopefully I will have some luck this time around |
Tue Sep 23 2014 10:08pm |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
You could drop the spare wheel out Yanislaw and take a short trip without it hanging below the car to see if this stops it. I agree, sounds like a good thing to check. |
Tue Sep 23 2014 10:18pm |
Rear hub knuckle bushes are known to produce a squeak when worn.... Bodsys Brake Bible
Tue Sep 23 2014 10:19pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
If you drop the spare wheel and then drive without the spare in place, take care with the cable. It needs a load on it when it's wound back in or it can cause issues (there was a thread on here a while back about it). Perhaps just carefully coil it up and tie wrap it out of the way rather than winding it in. 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 23 2014 10:33pm |
Guys, I think I found the source !!!
Wed Sep 24 2014 5:13pm |
Adrian ... Member Since: 24 Jan 2015 Location: Surrey Posts: 1 |
Seeing as no one else gave a thank you for that useful tip, I will. Rattles, squeaks and other noises are a pain ... |
Thu Jan 29 2015 10:16pm |
Glad I could help that noise annoyed me quite a bit for a while and hopefully no one will have to endure it in the future |
Thu Jan 29 2015 10:22pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
i have the same rattle but mine appears to be from the rear left of the car. i tried most of the things you have done and you would'nt believe some of the stuff i found right in the bottom of that little "compartment ".
Fri Jan 30 2015 7:22pm |
