Home > Technical > Running on 5 cylinders |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4347 |
An hour to take out all 6 injectors is time consuming, and expensive?
Tue Sep 16 2014 7:27pm |
W18ODY Member Since: 31 Aug 2014 Location: north east Posts: 87 |
Just to add to the list of problems (not sure if its related) the cars sat for a few days and i went to turn it over and it really struggled, really weak cranking then eventually gave up.
Wed Sep 17 2014 8:45pm |
You have to have the injectors tested, to find out which one is faulty... EDIT: There is the option to view the injector compensations via the diagnostics, but the OP has not mentioned having had this done. Over and above this, I have been in the position in the past where the car was showing 1 injector fault. This was replaced, and the fault moved to the next most worn injector. This continued until all 6 had been replaced, hence the suggestion to have all 6 tested at the same time To reseal the injectors, you use a new copper washer... When the fuel system has been disturbed, all open connections should be capped to prevent dirt ingress. Explicitly stated in most repair instructions issued by LR |
Wed Sep 17 2014 9:45pm |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
the op wants to find out what is wrong with his car,
Thu Sep 18 2014 8:13am |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 |
Take the injectors out and get them tested its a piece of silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Thu Sep 18 2014 7:57pm |
