Home > Faults & Fixes > Dynamic Response leaking |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
Sorry, don't have any part numbers but this is from the workshop manual for pre-face-lift RRS:
Which pipe has failed? If it's the one with the attenuators in then a home-made one might not be suitable. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Sep 12 2014 6:02pm |
OceanCarl Member Since: 12 Jan 2014 Location: Alicante Posts: 11 |
Thanks RRSTDV8,
Sat Sep 13 2014 7:17am |
hodjie Member Since: 13 Nov 2013 Location: United Kingdom Posts: 91 |
been waiting 10 weeks now for these pipes from landrover |
Sat Jul 01 2017 6:20pm |
From memory if front and rear ones that are leaking, then unfortunately they have to lift the body of car to replace.
Sat Jul 01 2017 8:24pm |
its the front os one . the specialist said its because its the petrol model ,so only limited supply |
Sat Jul 01 2017 8:42pm |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
Had to have mine replaced due to a leak last year, I seemed to recall they only came as a set at about £250, with the labour and replacement fluid the bill was about 900, I did have the single pipe replaced from pump to block at same time which was about £80.
Sat Jul 01 2017 9:33pm |
oh god they told me the pipes should be £400 but for the supercharged its come in at £200 .but theres none in the country . if I'm going to have to chew on like this I think il find a different brand . I get my tvr cerbera and lotus elise sorted quicker then this |
Sat Jul 01 2017 9:43pm |
Took this screen shot from local Indy garage I use, it was posted last week so seems to be a common theme
Sat Jul 01 2017 9:50pm |
thanks for that been looking at cayenne turbos tonight as an alternative ,and that's a first for me |
Sat Jul 01 2017 9:58pm |
The pipes can be bought individually, but it works out to be more cost effective to buy the 4 as a complete unit, individually each pipe costs nearly as much as the complete set, so you buy two and you've spen't more than it would cost to buy all 4..
Tue Jul 11 2017 10:17am |
hi ,thanks for the advice everyone . just had it in for a temporary repair , drove it home tonight and its still dumped half its fluid on the drive |
Tue Jul 11 2017 10:33pm |
Whatever is a temporary repair? Surely either repaired or not, for that fluid system. John
Wed Jul 12 2017 12:53am |
41664166@online.no Member Since: 01 May 2015 Location: Moss Posts: 127 |
Then I removed the plastic cover under the car on the driver's side. Found some gravel and mud there, so the pipes had rusted, and therefore holes in one. They were not pretty, so I wonder if I should change them all when I first do this. But found that they were not cheap, someone who has someone who can deliver at a nice price. Thanks in advance |
Tue Aug 04 2020 7:05pm |
Got repaired the leak in the pipes, but after filling with the right oem oil I experience a strange knock sound when I turn right. Is there any kind of blending for this system, or do the car it self.
Tue Aug 11 2020 4:23pm |
