Home > General > Noisy rattle from rear of 2005 sport
dani_armo
United Kingdom 2006 Range Rover Sport TDV6 HSE Siberian Silver
Over the last week or so I have noticed a noise coming from what seems like the rear suspension. The only way I can describe how it sounds is like a set of ladders rattling around beneath the car! Today the noise seems to have got a little worse (more clunky and a bit louder!)
The noise only really happens at lower speeds going over uneven bumps and holes in the road, rather that speed bumps or going up kerbs etc. I had to get a new tyre a month or so ago due to uneven wear - one of the rear tyres was really worn on the inside. Other than that the car drives fine.
Any ideas what could be causing this - cannot really find much on here other than possibly the rear sway bar?
Post #434639 Sat Aug 30 2014 6:26pm
simple1
diagnosis R us................by cystic meg.. Whistle
Lots of things make noise at the rear but I would guess drop links if audible at low speeds. Bushes, tie rods and rusty brake back plates are another favorite but don't cause a clonk or knock but rattle nicely. Plenty to keep you busy checking Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #434658 Sun Aug 31 2014 2:00am
RRS PIMP
Sounds like the brake shoes which sit inside the drum for the electronic parking brake needs adjusting.
If this hasn't been adjusted properly in the last year get them cleaned and adjusted and at the same time check the backing plate (dust shield).
Let's us know how you get on.... Very Happy
Post #434914 Tue Sep 02 2014 12:18am
robmeister1969
United Kingdom 2005 Range Rover Sport Supercharged Santorini Black
This sounds a little similar to a noise that's developed on my 2005 RRS SC although mine is coming from the front (at least it seems to be) and sounds like a metal on metal 'clanking'. Not especially loud and not related to going over bumps or braking. It almost sounds like the brake callipers are loose!
Post #435303 Fri Sep 05 2014 7:36am
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
I had rear rattle recently and it was the exhaust trim knocking against the enormous lead swinging thing at the back. Got the local exhaust fitter to apply a little heat and force the exhaust over a bit and is now fine
Post #435410 Sat Sep 06 2014 9:34am
