Home > Technical > pressed air suspension whilst driving - now its playing up?
wilpert
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
Nearly home from a 400 mile drive and with 50 miles to go, my son pressed access mode on tdv8
red warning light came up with "air suspension fault and max speed 30"
After a couple of stops on hard shoulder and with me resetting to normal height, it seemed OK.
2 questions:
1) would pressing the access mode whilst driving cause such a problem?
2) Is there some sort of reset that can be carried out manually, to reset things if this needs to be done?
Thanks in advance.
Post #434025 Sat Aug 23 2014 3:55pm
Paddi
wot no replies? Come on chaps. I'm no expert but pretty sure pressing the button should have no effect at any speed above a crawl. You just get a message on the dash telling you not to be a silly boy as you are going too fast to select access height. Just stopping switching off and restarting resets everything, there's no special procedure. 2008 MY Java Black TDV8 HSE
Post #434264 Tue Aug 26 2014 10:22pm
wilpert
Hello Paddi,
i was feeling a bit negleted tbh but i held out for a reply and here you are Very Happy
I still have a feeling that my son pushing the access height setting whilst i was flyinh along the M25 may have been part of the original problem but i will never know this.
Strangely enough, since i stopped and restarted the car I had done another hundred miles with no further problems.
that was up until today, when the amber light came up with an image of suspension and it beeped for literally a second and went off again?
Is there an air suspension service that should be carried out on these cars?
Post #434303 Wed Aug 27 2014 1:03pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
No servicing required unless you've had an actual problem with the pump itself. Eg not going up or down. Touching the button at speed should not effect the mechanics of the pump as I believe otherwise land rover would paint it red with a big warning not to press it above 30. try a hard reset if it it keeps playing up.
Post #434333 Wed Aug 27 2014 5:42pm
wilpert
Hello SCdavies,
I take your point about how it shouldnt affect things by pressing the button when the car is moving but it just seemed too much of a coincidence. Unless it went into access mode by itself and it wasnt my son pressing the button after all, makes me wonder now?
This all happened after 300 miles of continuos driving, so not sure if that would be a contributory factor.
Do the symptoms described point to anything specific, i.e. failed compressor, leaking pipes etc. or am I getting too far ahead of myself?
Is there an idiots guide to hard reset please, I think I will give it a try?
Post #434341 Wed Aug 27 2014 8:15pm
SCdavies
Reset. Remove both battery cables from battery and join them together for a few minutes. This removes any un wanted voltage that could effect some systems. Or pop to a dealer and ask for a reset via your plug in. Drivers side under the steering wheel. In our cars the switch won't operate over 30 to lower or higher excess modes. On the monitor screen go into the 4x4 area and your ll see each corner of the car. Operate the pump switch and you should see each corner ajust. If it's doing what it should I think your pump s fine.
Post #434356 Wed Aug 27 2014 10:10pm
wilpert
Thats a comprehensive reply SC, i appreciate your interest.
Ive looked at the image on the nav unit and it shows all corners lifting together etc, so I assume no issue with compressor?
another question though, I havent got a constant error message or light on the dash, so will the reset via the battery leads off have any benefit?
will resetting via the battery leads off method, clear the history of an error?
thanks,
Post #434388 Thu Aug 28 2014 1:29pm
SCdavies
If you have no codes showing then don't worry about a reset. It seems your pump is working fine so I would nt worry about unless any more messages show. But if you get a dealer to plug your car in the fault codes will stay until you get them cleared. I had mine done last and since new the car had 96 stored codes.
Post #434415 Thu Aug 28 2014 7:00pm
wilpert
I havent any faults showing, it went off after I stopped the car.
My concern about clearing the stored codes were that I will be having the car inspected for the Warranty Direct warranty that I have just taken and Im concerned in case they plug in and find the codes and then elect to exclude these items.
Im not sure what type of inspection they do but if its just a visual and test drive and they dont plug in then I will be Ok.
Perhaps thats me being optimistic though.
Post #434445 Thu Aug 28 2014 9:23pm
tailormadefun
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
You may not have a fault showing on the dash, but a fault can still be stored in the ECU
Get it plugged in and it will probably point you in the direction of what went amiss
Post #434475 Fri Aug 29 2014 4:34am
wilpert
just had a call from Mrs Wilpert, the suspension warning light is back on, she is going to the dealers today for a plug in to diagnostics.
Post #434483 Fri Aug 29 2014 10:41am
wilpert
Update:
Indie garage plugged in and advised that compressor is faulty and not producing enough pressure to do the job.
Quoted in the region of 800-00 + VAT inc software update.
Is this realistic?
Im doubting my warranty would even consider it as i only just took out the policy.
Im not over keen on spending a grand atm Sad
Post #434496 Fri Aug 29 2014 1:05pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
..sounds expensive. Had mine replaced with software update at my local main dealer about 18 months ago for just over £500 all in... Carl
Post #434595 Fri Aug 29 2014 11:25pm
wilpert
That sounds like a very good price to me.
I thought the part alone was over 500 quid.
My garage are quoting 150 quid labour plus 650 parts plus diagnostics 50 quid (all inc vat)
Im sure they have a mark up on parts and thats fair enough but i dont want to pay way over the odds.
Post #434603 Sat Aug 30 2014 8:41am
SCdavies
Would nt pay more than £500 all in. It seems the pump has just got tired. Works ok but just slow. They have an average life of 60,000 miles. You can buy refurb kits for a DIY fix if you have a little mechanic in you.
Post #434607 Sat Aug 30 2014 9:56am
