Home > Technical > Some sort of electrical problem |
These RRS are very temperamental when it comes to the electrics. A lot of your issues will be caused by the dead battery. You really need to give it a FULL charge or replace it like for like if the battery is naff. Are the rear lights smashed too? Faulty rear brake light bulbs cause all sorts of warning lights to show up on the dash.
Thu Aug 21 2014 1:06pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Have you checked the fuses (behind the glovebox) ?
Thu Aug 21 2014 1:08pm |
Dappz Member Since: 21 Aug 2014 Location: South yorkshire Posts: 4 |
I have put a brand new battery in it. Only 1 tail light is smashed and the wiring that goes from the top of the tailgate towards the roof lining is cut just before the plugs so I will be need a new loom for the tailgate. I've checked the fuses in the fusebox under the bonnet just beside the battery and the are all ok.
Thu Aug 21 2014 1:21pm |
There is a fuse box behind the glove box yes that should control the windows etc - it's worth checking, details of which ones do what will be in the Op manual. ON THE WAY: BMW F21 M140i
Thu Aug 21 2014 1:25pm |
I would only perform a hard reset when you have sorted your rear lights and tailgate wiring loom. Otherwise you will still be getting a dashboard lit up like a christmas tree.
Thu Aug 21 2014 2:51pm |
I'm away from the vehicle until next week and I shall check all the fuses behind the glovebox and if that don't solve it then I'll do the hard reset once I've sorted the tailgate and tail lights outs.
Thu Aug 21 2014 7:15pm |
