Home > General > New Owner, RRS Supercharged. Help please.. |
Bungleaio Member Since: 06 Apr 2014 Location: Leicester Posts: 172 |
Hi Ian, I don't know about the screens/dvd or coolant issues but I'm surprised you have an aftermarket Bluetooth kit fitted to the car as they should come with a factory fitted kit.
Wed Jul 23 2014 8:43am |
ian-r Member Since: 21 Jul 2014 Location: Nottingham Posts: 49 |
Cheers for the reply.
Wed Jul 23 2014 9:06am |
Fair play, if it's a flash lube kit they install then I have about 4 litres of it left from when I had an impreza which was on LPG. You are welcome to it if you want it, I'm just off the M69. |
Wed Jul 23 2014 9:23am |
speedy2009 Member Since: 04 Apr 2014 Location: driffield Posts: 35 |
Don't LPG it it will all go wrong just leave the car be mate |
Wed Jul 23 2014 10:45pm |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
this is a default feature as far as im aware of it, mine does this also, unfortunately. I know that Bodsy has a solution, check this thread for example: http://www.rrsport.co.uk/forum/post427587.html#427587 Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Wed Jul 23 2014 10:55pm |
Bungleaio: Thanks very much for the offer, very kind of you.
Fri Jul 25 2014 4:20pm |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 |
Hi ian-r
Fri Jul 25 2014 6:50pm |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 |
Dont replace sensor it wont work buy complete expansion bottle, definitely dont lpg flash lube crap or not your car will suffer valve recesion , sorry for being a tad abrupt but Ihave been there on both silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Fri Jul 25 2014 8:18pm |
i know this guy can upgrade the bluetooth module but it shows that he's away, so maybe it is Bodsy:
Sat Jul 26 2014 10:37am |
tailormadefun Member Since: 06 Apr 2014 Location: Kent Posts: 51 |
Hello mate I have the same car as you,
Sun Aug 03 2014 9:21am |
Thanks everyone. Do you have a link for the part, or is that from a motor factors ?
Sun Aug 03 2014 10:52am |
jenko2005 Member Since: 29 Jul 2014 Location: Rhoose Posts: 142 |
i had converted a 4.6hse p38 with only 24k on the clock a few years ago to gas spent about 5k on the gas kit top of the range, went through 4 catalytic converters it never ran the same after i ended up part xing and taking a big loss dont make the same mistake as i did you will regret it |
Sun Aug 03 2014 5:21pm |
i have owned 3 lpg rr and all up big time silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Sun Aug 03 2014 6:23pm |
hodjie Member Since: 13 Nov 2013 Location: United Kingdom Posts: 91 |
i cant understand why you would buy a supercharged when you cant run it as intended |
Sun Aug 03 2014 6:45pm |
