Home > Technical > HDC Disabled, Transmission fault Special Programs disabled |
stevew Member Since: 16 Oct 2013 Location: solihull Posts: 75 |
I had the same thing happen me to me, but it was found that my rear diff motor had packed up, luckily enough I had extended warranty and my local dealer replaced it. I was told that it would have cost me about £600 if I did not have the warranty |
Sun Jun 01 2014 6:23am |
Nickr6r Member Since: 28 Jun 2014 Location: Burnley Posts: 50 |
Hi guys I'm new on here and not to sure how to use the site so please let me no if I'm going wrong rite I have if problem with my 2005 rrs tdv6 I jump in and start it up and I get hdc fault system not available / suspension fault /transmission fault and the car is as low as it can go and will not raise also green lo mountain light flashes all the time with amber lights ether side can any one shed any light |
Sat Jun 28 2014 11:22pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4349 |
Nick, it could be anything. You will have to have the car plugged in, to diagnose any fault codes stored.
Sat Jun 28 2014 11:29pm |
MartyRRS Member Since: 04 Dec 2013 Location: Adelaide Hills South Australia Posts: 25 |
If the problem is still there after replacing the bulb and/or brake switch you could try replacing the fuel filter, especially if it has not had a good or regular service history. On my TDV8 RRS it was the fuel filter that caused the cascade of warnings. Good luck, and as Mikey said, try and get your codes read too. Regards, Marty
Sun Jun 29 2014 3:06am |
Thanks i will get it plugged in as iv change the battary for a new s5 bosch and replace the brake peddle switch .dont no if it makes a difference but my brake swich was blue and white but the one i got to replace it was blue and brown they assured me it was the right one but coule just have said that to make a sale .any way i will get it plugged in asap thanks |
Sun Jun 29 2014 10:22am |
Also forgot to mention i blanked of the egr's but thats seemed to be fine when i did that |
Sun Jun 29 2014 10:34am |
Eballs28 Member Since: 01 Nov 2013 Location: Sussex Posts: 10 |
Just to add my input, I had the same problem, and new battery didn't help. Checked bulbs and all ok. So got a new brake light switch for £5 +VAT from Island 4x4 and it solved all my problems! |
Mon Jun 30 2014 10:20am |
I replaced the brake light switch and still no different cost me £20 was blue and brown is there another brake light switch ? |
Tue Jul 01 2014 10:24pm |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 |
i would start from checking Transfer Case ecu for corded connectors
Wed Jul 02 2014 6:58am |
Ye i did power wash under the bonnet when i got it as the whole car needed i good clean ill have a look and see what i can see thanks |
Wed Jul 02 2014 12:48pm |
So at least no one else to blame |
Wed Jul 02 2014 6:20pm |
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Wed Jul 02 2014 8:54pm |
Well thanks very much disco_mikey you was spot on was the ecu plugs that were corroded took it out give it a good clean and the car runs spot on no faults at all thanks for everyones help |
Thu Jul 03 2014 5:54pm |
My transfer case ecu and plugs cant belive it .this is a great site thanks again disco-mikey
Fri Jul 04 2014 7:37am |
