Home > General (L494) > Performance of the SDV6 with On/Off road pack vs. SDV8 |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1289 |
Doesn't fee; sluggish....
Wed Mar 19 2014 10:23am |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 |
See other area's on the forum , lots of info SDv8 V SDV6
Wed Mar 19 2014 12:21pm |
DBA Member Since: 20 Mar 2013 Location: Skopje Posts: 51 |
Thanks for the feedback!
Wed Mar 19 2014 12:49pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
The hi/low range transfer box adds 15kg to the overall weight of the RRS. The other bits won't add a huge amount more.
Wed Mar 19 2014 1:49pm |
Hmm... But if the hi/lo range is just 19 kg and torque vectoring is just a software.
Wed Mar 19 2014 2:20pm |
Where are you getting the 300kg difference from? At launch, several reviewers quickly pointed out that the weights quoted by LR were way out. There was a big thing made about the new RRS being 400kg lighter than the old one. It is if you choose to compare the old S/C or TDV8 and new TDV6 with no kit. The reality is that the new RRS is not hugely lighter than the old one in most trim engine/trim packages.
Wed Mar 19 2014 2:59pm |
The SDV8 is rated at 2398 kg as opposed to 2115 kg for the SDV6 (so 283 kg heavier), in the official Land Rover tech. specification documents:
Wed Mar 19 2014 3:12pm |
work out were the weight changes are that is the point of the posting made it's not the weight of the engine as a whole ! Even the press release there is wrong on the 4.4 suspension not shocked of course ! 2014 5.0SC AB
Wed Mar 19 2014 3:29pm |
Note that it says weight "from" and then the figure. I believe the SDV6 doesn't get down to that weight in reality because it has higher spec (more kit such as multi-movement seats etc. and all of that adds weight) than the base weight (which was the bsaic SE version). 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Mar 19 2014 4:29pm |
The weight reduction isn't really a reduction though...they removed all the bits and made them optional to make a big deal that the car was lighter than previous version and for emissions etc
Wed Mar 19 2014 5:51pm |
Yeah Ha - Exactly - only if you buy a bog standard Se comparable model with no extra's will you get that kerb weight
Wed Mar 19 2014 6:18pm |
indeed
Wed Mar 19 2014 6:36pm |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 323 |
More Power ist There, more sound also. But Power is not everything.
Wed Mar 19 2014 8:40pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1826 |
Renaco are you saying the sdv6 diesel is the best diesel or get the SC. SVR 2018 in Santorini Black. |
Wed Mar 19 2014 8:49pm |
