Home > General > Removable tow bar - Light Duty?
SimonR
I have one of the removable tow bars - but read on one of the forums that this is considered 'light duty'. What is not so clear to me is what is considered light or heavy duty towing? But it has worried me some!
I'm towing a Brian James 3.5 Ton transporter trailer which I guess usually weighs 2.5 Ton when loaded.
I spoke to the main dealer and they said my tow bar is rated for 3.5 Ton and is fine for the trailer. They said the Heavy Duty tow bar is for 'professional' towing - all day every day. But this seems at odds with what I've read!
The internet would have you believe my tow bar is barely suitable for pulling skins off rice puddings!
I just don't know what / who to believe! I definitely don't want my trailer parting company - but I don't tow regularly enough to warrant the cost 'HD' bar if it's not necessary. Since reading about it, I've been towing with my Defender instead (but would rather be in the RR).
Si
Post #416494 Tue Mar 04 2014 12:43pm
simple1
I towed twin wheel caravan, Brian James race shuttle and a plant trailer. Only issue I found was that the bar worked down over large mileage but if you want secure, the heavy duty version with bolt on legs is the best version 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #416496 Tue Mar 04 2014 1:00pm
muddywheels
Milk Float Man
I tow a twin axle caravan (1.7 Tonne) with no issue but have read on here of others with concerns - Simple1 I think Confused
Edit - Beat me to it Bow down
According to LR Website -
Quote:
Please note the Quick Release Tow Bar is intended for leisure use only
The multi height states -
Quote:
This heavy duty tow bar is intended for commercial and constant use
 Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #416498 Tue Mar 04 2014 1:06pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
I tow a 23 ft phantom powerboat on a 4 wheel trailer.no problem.
Post #416508 Tue Mar 04 2014 1:20pm
It's not a question of can you tow regularly with the removal bar, it's a question of should you do so. People can and do (see above) but LR say you shouldn't. If you tow a heavy trailer every weekend then you should fit the HD bar according to LR. 2012 SDV6 - it's missing a couple of cylinders
Post #416541 Tue Mar 04 2014 5:02pm
Mark_TDV8
England 2007 Range Rover Sport TDV8 HSE Cairns Blue
Simon,
I have the HD tow bar attached to mine - you are welcome to a look this evening if you wish?
Mark 2007 TDV8 RR Sport HSE
2003 TD5 Discovery 2 ES
2001 TD5 Defender 110 DCPU
2003 4.4 RR Vogue [Project]
Post #416547 Tue Mar 04 2014 5:22pm
Kiwi Graham
New Zealand 2007 Range Rover Sport TDV6 SE Stornoway Grey
I have both types of detachable tow bar and tow many different things from horse floats, bike trailers, agg trailers to heavy (4 tonne) boat trailer from a compound to the launche ramp plus I have just purchased a large caravan.
No issues from my end, hitch fits nice and snug (both of them), I always lock it and remove the key and have full confidence in the engineering.
KG
Post #416577 Tue Mar 04 2014 7:57pm
