Home > Maintenance & Modifications > Parking sensors |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
Sounds like one is faulty somewhere. Have you got them very wet recently? A wet sensor will give what you describe. |
Sat Jan 25 2014 3:09pm |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 |
Yeah don't go near them with the jet wash sent mine crazy fo ages... |
Sat Jan 25 2014 4:12pm |
K80tcg Member Since: 29 Mar 2013 Location: Verwood Posts: 25 |
The car been sat in the sun today and long beep has stop to little ones which then stops, they started working, but the tone cuts in and out.
Sat Jan 25 2014 4:19pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Had exactly the same problem - during dry periods - not a problem as soon as it rained - intermittent fault. Eventually they will give up its a common fault - they don't last forever. Another part to add to the consumables list
Sat Jan 25 2014 5:50pm |
Where the best place to get a code reader from. Does it tell you which one of the eight has gone ? Tdv8 range rover sport
Sat Jan 25 2014 7:40pm |
Silly questions, if the sounder at the back is holding the long tone does that mean the rear sensors is at fault? Tdv8 range rover sport
Sun Jan 26 2014 5:19pm |
