Home > Tips & Tricks > If you have squealing rear brakes read this
RRUK
Be warned, you need to get this fixed before 10,000 miles or your first service, which ever is first otherwise it will not be covered by the warranty and the dealer will want to charge you about £90 to fix it.
I found this out today to my peril and told them to leave it alone in that case.
06MY FFRR Vogue TD6, JE Stage 1 Tune, Chrome Tubes, Full Privacy, Full Fat, Full On.
Post #40884 Thu Jun 22 2006 5:19pm
Tim in Scotland
Why didn't you allow them to fix it RR?
Apart from parting with ninety good notes what is your reasoning as I was under the impresiion that one of the causes of the squealing was an electronic parking brake not releasing properly and causing damage to the system.............remember that Land Rover parking brakes are not the same as on "normal" cars, they act as a clamp on the propshaft rather than on the front or rear brakes which is why, when I leave my car while I'm away, I don't leave the EPB on or the handbrake on my Def on as they can corrode to the propshaft. I have recently learned that the EPB will actually engage itself after a while so that may be a problem for me to overcome at some time! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Tata TDv8 HSE - Stornoway/ebony and straight grain walnut with towpack, Tasmods and an HST grille. Coming soon LEDs in the headlights
Staying - Epsom Green Defender 90 for playing off road
Post #40888 Thu Jun 22 2006 5:33pm
RRUK
I left it because it only squeals every now and then and not every time I release the EPB. If it WAS every time I would have it done for sure.
98% of the time I get no noise at all.
But in case anyone else gets this issue in a big way they need to know the rules!
Post #40889 Thu Jun 22 2006 5:42pm
Tim in Scotland
Cheers, agree with you about if it is happening regularly to get it looked at. The only time I have ever suffered it has been when the car has been offroad and usually an underneath washing session with the garden hose seems to cure it. A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #40891 Thu Jun 22 2006 5:50pm
Cyprus 2006 Range Rover Sport TDV6 HSE Java Black
Ours does it intermittently but as it now has 7,500mls on the clock ( Shocked ), I will get it done whilst having recall for hoses and software update done.
Thanks RRUK! 06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods, Black Badge Soon...
PLEASE HELP DEVELOP TROTTERLAND, JUST CLICK A DIFFERENT LINK EACH DAY:
Population - http://trotterland.myminicity.com
Roads - http://trotterland.myminicity.com/tra
Industry - http://trotterland.myminicity.com/ind
Crime - http://trotterland.myminicity.com/sec
Post #41037 Fri Jun 23 2006 12:48pm
Mine does that too every now and again, but given I'm past my first service and now on nearly 18k miles I might have missed the boat a little bit! Evil or Very Mad
Post #41090 Fri Jun 23 2006 2:22pm
Slimer
Tim in Scotland wrote:
.....remember that Land Rover parking brakes are not the same as on "normal" cars, they act as a clamp on the propshaft rather than on the front or rear brakes ...
Not in the case of the RRS & D3 Tim, the EPB operates a set of shoes against a drum at the rear inside the disks on both sides
Post #41093 Fri Jun 23 2006 2:31pm
Tim in Scotland
Cheers for that Slimer, something new learned for today! Laughing A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #41132 Fri Jun 23 2006 3:43pm
RRUK
True, service dept told me that too, they mentioned "drums" and I harked back to my Series 3...I said...Doesn't it have discs?
Anyway, you now know the answer.
Post #41163 Fri Jun 23 2006 4:20pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Re: If you have squealing rear brakes read this
Why is that (10K miles or first service whichever comes first)? If it is a defective EPB causing the squeal, or any other cause other than worn pads or rotors, shouldn't the full warranty on the car cover it? There's even a TB on the EPB issue.
Post #41261 Fri Jun 23 2006 9:59pm
That's exactly what I was thinking too Confused
Post #41338 Sat Jun 24 2006 2:38pm
Dealers = Stealers. FACT! 06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods, Black Badge Soon...
Post #41622 Mon Jun 26 2006 10:52am
Donkey Dan
Noisey Rear Brakes
New here fellas! There are modified rear handbrake shoes available for RRS and dealers will change them regardless if you have a good dealer.
Post #70553 Wed Dec 13 2006 7:01pm
Landlord
Location: Still Cold, Still Wet and Still Bloody Windy Devon.......Again
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Thanks for info Donkey worth noting 07MY TDV6 HSE, Zermatt Silver, Privacy Glass, Tow Bar, Phone Cradle, Mud Flaps
On order Hybrid 3lt Sport ......expected 2009
LR Defender 07
Post #70557 Wed Dec 13 2006 7:33pm
Re: Noisey Rear Brakes
Would these "shoes" be the same for every model ??
Post #70612 Thu Dec 14 2006 10:41am
