Home > Technical > Front Windscreen Washer
norman1979
I have an issue with my front windscreen washer not working. The rear one works perfectly fine which is what I dont understand. Nothing happens at all when pressing the button on the stalk. Not even the noise of a pump.
Any body have any ideas?
Post #406925 Sat Dec 21 2013 7:13pm
Paddi
Have you checked the fuse? If the fuse is OK but pump definitely not running it is possible the pump has failed. Common at this time of year when pumps can freeze and suffer consequent damage if the concentration of washer fluid is too low. To access the pump you have to remove the front nearside wheelarch liner. Sometimes the pipe drops off the pump and can be pushed back on but if that was the case the pump would still run, Pumps are fairly inexpensive and easy to change once you have access Thumbs Up 2008 MY Java Black TDV8 HSE
Post #406977 Sun Dec 22 2013 2:09pm
