Home > Technical > info 4x4 display shown a red line on the top of wheels |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Your RRS is in access mode - did you lower it keep it on this screen & drive over 10kph it should raise & the line disappear - this is normal 16MY Estoril Blue SVR.............
Wed Dec 04 2013 6:26pm |
urimg Member Since: 01 Dec 2013 Location: Firenze Posts: 20 |
Aha yes it's in lower position so we can't drive in lower position |
Wed Dec 04 2013 7:57pm |
You can drive in the access mode - very slow
Wed Dec 04 2013 8:05pm |
Aha thanx very much this is so helpful for me because sometimes I drive in acces mode and I lock it so from now I will put in normal mode |
Wed Dec 04 2013 8:18pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
The red lines indicate that either the suspension is at full compression or that there is a fault in the ride height sensor. If the red line goes away when you have it in normal ride height mode then nothing to worry about. If the red line stays there in normal height mode then you might need to change the ride height sensor. Not a big job but the suspension should also be recalibrated afterwards. 2012 SDV6 - it's missing a couple of cylinders
Wed Dec 04 2013 8:32pm |
Yeh thanx I think that a access mode is a problem here because when I drive sometimes red line goes
Wed Dec 04 2013 8:40pm |
