Home > Wheels & Tyres > Tyres with different tread depths on same axle |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 |
As long as both are legal, I don't see it makes any difference? |
Sat Nov 30 2013 10:37pm |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5584 |
If you read the handbook all 4 tyres should be replaced at the same time on the rrs but it says if this is not possible replace pairs on same axle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Sat Nov 30 2013 10:45pm |
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 286 |
Judging by the differences we see on customers cars I don't think there are ant big worries.
Sat Nov 30 2013 11:05pm |
I have MTR's and tread depth on one rear is 11mm and the other rear is only 4mm.
Sun Dec 01 2013 10:43am |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Bodsy - do you ever pick up your phone messages 16MY Estoril Blue SVR.............
Sun Dec 01 2013 10:45am |
Of course.... Bodsys Brake Bible
Sun Dec 01 2013 11:21am |
Of course - 16MY Estoril Blue SVR.............
Sun Dec 01 2013 11:28am |
^^^^ Peachy / Bodsy - Not sure what the 3 posts above have to do with the rest of us !
Sun Dec 01 2013 11:44am |
Tonyrec Member Since: 15 Mar 2009 Location: Cumbria Posts: 306 |
Thanks for the replies.
Sun Dec 01 2013 6:54pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8853 |
In extremis, if one tyre was brand new and the other side of the axle had a tyre at the legal minimum depth you could find the stability control system gets a bit twitchy because of the difference in wheel speeds across the axle. But at 2mm difference in tread depth, as already mentioned by drdelrrs, it's going to be close enough to be lost in other variables. 2012 SDV6 - it's missing a couple of cylinders
Mon Dec 02 2013 10:53pm |
Presumably the system expects the relative rotational values to be within certain values. If one tyre is excessively worn then it might fall outside of the relevant rotational value. That's my guess.
Wed Dec 04 2013 2:20am |
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 |
I was having a similar discussion with my colleague the other day, and mentioned that I had different tread depths on my tyres, but on different axles (front to rear).
Thu Dec 12 2013 3:03pm |
The centre diff should always see zero relative motion between axles except on those rare occasions that one end is e.g. spinning both wheels i.e. in off road type conditions. It's designed to handle short term speed differences but not, I would guess, constant differences. By running with constant positive relative speeds between axles you will have shearing of the oil between the plates in the coupling and hence the temperature will rise. This probably isn't good for the oil. However, one would expect some tolerance in there somewhere.
Thu Dec 12 2013 5:25pm |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 |
Look at it from the other direction, you may have to replace tyres on one axle because they have worn quicker, fronts usually wear first, so the car in its original form is wearing tyres at different rates causing differences in rotational values across the axles, so unless you have 20's on the back and 19's on the front, it's not really going to be an issue..
Mon Dec 16 2013 10:03pm |
