Home > Advanced Factors > Osram replacement front FOG Lamps with DRL kit
Advanced Factors
Site Sponsor
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
It may be they will fit straight into later models, not got one to look at Big Cry
If you have 95mm Fogs, they should, Osram list them to fit, although my D3 isn't on the list, perhaps that's why I had to work a little harder. You are welcome to try a kit and return it if they don't fit the bill. Does that mean you have to take the bumper off to get to the lamps then? Paul Redding
+44 (0)23 8052 2774
Order Parts Online at www.advancedfactors.co.uk
Post #402945 Wed Nov 20 2013 7:45pm
muddywheels
Milk Float Man
Probably Thud
Don't fancy being the guinea pig so will wait until someone else tries them first Embarassed
NOW GONE
MY17 Lexus RC 300h F Sport
MY16 DS
MY10/13 RRSs - Mini One
FL2s
Jag X-type
D2s - MGTF
FL1s
Landcruiser, Mondeo, Escort, Orion, Astra GTE, Xr3i, Renault 5/19/18, Fiesta 1300S, Allegro, Avenger, Honda MTX, Yamaha FS1E
Post #402947 Wed Nov 20 2013 7:48pm
Knowing your luck Muddy, you will fuse all your electrics and blow both headlight bulbs. Laughing Go on, be a guinea pig. Wink
You could be right Steve, chances are they might fit straight on to a sport .
Post #402953 Wed Nov 20 2013 8:36pm
Advanced Factors
Site Sponsor
Yes, I have been looking at the bumpers & lights, early Sport is the same as my Disco, later bumper style has the same light bracket arrangement as the Osrams so I am pretty confident they are a like for like fit. Paul Redding
+44 (0)23 8052 2774
Post #402959 Wed Nov 20 2013 9:03pm
drdelrrs
Sounds like a good idea and I was interested up until the point when it turned out they didn't fit without modification.
Because, if you modify the lamp its obviously not returnable and if you need to modify the car that's probably not a good idea either.
I'm quite happy to dismantle, refit and/or repair but I'm afraid that if I buy a new item my expectation is that it fits (out-of-the-box) if not my interest drops off steeply.
Post #403065 Thu Nov 21 2013 3:27pm
defender_uk
England 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I don"t understand why the light opposite the indicator goes out....normally the indicator side dims and the opposite side stays as it is..so a bit lost...otherwise still interested as I have MY 13 so hopefully will just fit on
Post #403104 Thu Nov 21 2013 8:10pm
shadrack
its the cornering assit, loads of new cars do it, but the fog comes on with the indicator whats on
Post #403106 Thu Nov 21 2013 8:20pm
maci234
anyone fitted them to a range rover sport 2005
Post #465406 Mon Jun 22 2015 7:36pm
Bodsy
Site Sponsor
Maci, speak to Disco_Mikey he's in your neck of the woods. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #465408 Mon Jun 22 2015 8:08pm
maci234
ok thanks
Post #465422 Mon Jun 22 2015 9:18pm
maci234
can anyone tell me what are negative spacers if you use this then there is no trimming of fog light bezels needed
Post #474535 Sun Sep 27 2015 9:24pm
