Home > Technical > front end dropping to access height when parked
LOCUST
Hi all, if i park in either off road or normal height the front end drops to access height after a few hours, is this a sensor issue or something vastly expensive ?
its fine when i start and drive, no issues or errors come up, i usually put in in access mode anyway but the odd time i havent i come home and its fronts dropped.
if i put the 4x4 screen up i see 2 red lines above the wheels which dissapear when i start and normal height is selected.
cheers
Post #401978 Wed Nov 13 2013 9:41pm
flack
If its dropping then you have an air leak on the front either at the valve block air pipe or a air bag on one of the front legs..
Flack Thumbs Up
Post #401982 Wed Nov 13 2013 9:55pm
LOCUST
thanks, wouldnt an air leak throw up a warning ? and would there be an air leak on both sides ?
If i got it plugged in to a diagnostic, should that gime me the correct error codes ?
Post #401992 Wed Nov 13 2013 11:09pm
The system wakes up and levels itself every 6 hours so a leaking bag might cause the vehicle to "chase" the front end down in order to stay level. I would have thought, however, that a leaking bag would cause the compressor to work overtime whilst driving and this would then throw up an over-temp error code.
More likely is a valve block issue. Hopefully it's the front valve block (it's behind the front part of the OSF wheel arch liner). A new one is a couple of hundred quid I think. If it's in the main valve block by the compressor then that's a bit more expensive.
Search on the forum for a thread where someone stripped and cleaned the front valve block. Might be helpful. 2012 SDV6 - it's missing a couple of cylinders
Post #402010 Thu Nov 14 2013 1:42am
LOCUST
thanks,
ok on starting this morning it said suspension raising very slowly or something on screen, and the red line was over the front left wheel for ages, so I assume the issue is with the front left.
Post #402032 Thu Nov 14 2013 10:49am
Paul Holywood
Locust, can we have an update on your findings please, as mine is very similar.
Post #411259 Mon Jan 27 2014 12:39am
LOCUST
Hi, i had my valve block out the weekend, and it was very gunked up, ive cleaned it, its better but still drops so will get a new one,
ive attached a pic of how it looked and it clearly looks like its leaving condensation from the seals...
Post #411326 Mon Jan 27 2014 3:57pm
LOCUST
pic
Post #411327 Mon Jan 27 2014 3:59pm
Paul Holywood
thanks for the update mate Thumbs Up
how much and where did you go for your air valve?
also was the front valve easy to get to under the drivers wheel arch?
Post #411344 Mon Jan 27 2014 6:51pm
LOCUST
Speak to dan at duck worth parts on here. 78 quid plus vat I've not got it yet.
It's fairly. Easy to get to, except I've got a sc and there is a wacking great rad in the way which I didn't know about until I removed the inner arch !,,
Post #411357 Mon Jan 27 2014 8:04pm
Paul will have that radiator too in the TDV8... 2012 SDV6 - it's missing a couple of cylinders
Post #411358 Mon Jan 27 2014 8:06pm
Paul Holywood
There's a fella who stripped one down on here, done a good write up too , but i dont remember him mentioning rad, so you may be ok Thumbs Up
ps i will contact Dan to order this first i think.
cheers Wink
Post #411360 Mon Jan 27 2014 8:10pm
LOCUST
I followed that strip down guide but I don't know if mine is beyond service. As from the pic it seems to be leaking condensation form the join.
Also the rings inside we're quite hard so I may get a new one.
Post #411385 Mon Jan 27 2014 9:09pm
Paul Holywood
It's not ecacly a lot of money so i would just go with that to start, as i am. Wink
Post #411397 Mon Jan 27 2014 9:33pm
LOCUST
Lol I get you. But I'm not gonna start chasing my tail replacing parts and hoping.
Been there and out of pocket with other cars! Namely renaults lol
Post #411402 Mon Jan 27 2014 9:46pm
