| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Maintenance & Modifications > Low Coolant warning message |
| kam100 Site Sponsor Joined: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4200
Mine comes on/off all the time too, apparently they replaced the sensor as it was faulty, but it kept coming on.. mine might be telling the truth too then! will check it when i get my car back.. Past: Bmw M3 Coupe 57, 335d Coupe 56, Audi RS4 06, RR Sport TD HSE 05,
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 8082
Just found this thread after posting a new one! Looks like I have the same problem Matt! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
| Zipperman19 Joined: 22 Aug 2005 Location: South Florida Posts: 85
I've had the same problems. Had the glitch and had the the tank replaced. Started getting the warnings again and thought nothing of it. While at the dealer today i mentioned it, and it actually was low. The pressure tested it, but found no leaks. |
| MDP Joined: 14 Jun 2005 Location: Back in an AUDI Posts: 8598
As mentioned elsewhere recently - I too have just had a few Low Coolant warning messages.
Mine was very low so don't ignore the warnings! For the last week I been adding Coolant/ Antifreeze and water in a 50/50 mix to refill back to minimum.
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 15238
This has now happened to me too. Had the RRS's first service - 2 weeks later Low Coolant warning comes on! RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
| d3matt Joined: 11 Jul 2005 Location: Oxfordshire, UK Posts: 729
Mine flashed up the message for the first time in the LR dealers car park when collecting the car after the first service.
Just checked - plenty of coolant. Another warranty job I feel! RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
| umbertob Joined: 22 Sep 2005 Location: Pasadena, CA Posts: 739
There's a brand new (June 12) Tech Bulletin out for this. I had the same issue. Here you go fellas:
Umbertob - thanks for that but my VIN is a 5A****** but probably the same cure. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
When it comes to RR Sport I have never seen a tech bulletin from Land Rover referring to 05 VINs when indicating a range of early builds, yet they obviously built some and they surely share the same parts (and problems) as 06s... I wonder why that is |
| texas911 Joined: 02 Jun 2006 Location: Houston, Texas Posts: 30
My 05 LR3 had the same problem with the faulty sensor. The dealer changed it out. 2006 RRS Silver/Black |
So did my RRS until they fitted the FBH and then it really did loose the coolant for a week afterward, very alarming! Turned out not to be the float or a leak, it was air in the system being pumped round. I must admit I wrote a screed on the "how did you rate our service" letter that came from LR and the dealer about it............. why when they had the car for a week and used 1/4 tank of fuel did they return it with less coolant than it needed??
| XXXAngelXXX Joined: 03 Mar 2006 Location: assimilated....... by the Britts - since 1995 ! Posts: 5486
talked to my stealer today and he told me the most problems with the RRS is the low cooling warning.... they exchanged the expansion tanks 2006 RRS TDV6HSE java black/alpaca
| All times are GMT |
Staying - Epsom Green Defender 90 for playing off road
