Home > Faults & Fixes > Cracked Windscreen |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Problem is, it could well of taken a whack in transit, even if there are no signs of damage it could of weakened it and the heat (or even a bad condition road?) has compounded it
Fri Aug 09 2013 2:59pm |
If you go down the insurance route for a replacement make sure they fit an LR part.
Fri Aug 09 2013 4:27pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
My non-LR replacement screen has every single marking as the LR-marked ones do and is made by the same people who make the LR-marked ones. Not sure what difference having the LR logo makes other than adding to the cost... 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 09 2013 4:37pm |
I see the crack is in the exact position as mine which went while driving through France - parked up at the time!!
Fri Aug 09 2013 8:38pm |
When mine was replaced, by Autoglass, they also replaced the side trims and clips.
Sat Aug 10 2013 3:16pm |
^^^ My post said "Sorry RRSTDV8 but the manufacturer is not the OE supplier. " which doesn't say that LR manufacturers its screens. JLR is and assembly company 'making' next to nowt |
Sun Aug 11 2013 9:28am |
That's not strictly true which doesn't mean they don't design and engineer solutions Mike 2014 Facelift Discovery |
Sun Aug 11 2013 10:34am |
East Coast Sport Member Since: 23 Jul 2013 Location: Angus Posts: 78 |
Hats off to Gary and the boys at Auto Windscreens in Aberdeen on a first class job. He even told me that the design of the clips that hold the exterior trim in place has changed on 2013 my therefore the ones he had ordered were not quite the same shape.
Fri Aug 16 2013 3:05pm |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
LR Insurance shouldn't have any problem fitting LR OEM Parts, its part of your cover (like mine) that they only fit genuine LR items, whether its glass or body work
Fri Aug 16 2013 3:27pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
does anyone know if there are two fuses for the front windscreen heater circuit?
Tue Aug 27 2013 9:48pm |
Not sure on fuses, but there are 2 connectors, one for each side
Tue Aug 27 2013 10:06pm |
I guess I best get them back out to it anyway.... frosty mornings wont be far off |
Tue Aug 27 2013 10:10pm |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
I had a cracked screen six months ago and Autoglass fitted a generic non-LR screen through my insurance. However, the rain sensor didn't work and they acknowledged the car required a genuine screen so they got one and refitted it a week later. A fair bit of hassle but no extra charge and everything worked properly with no further problems. Unfortunately, this new screen recently cracked so I rung Autoglass and requested a genuine LR replacement, sighting previous issues in an attempt to avoid a repeat of the double-fitting fiasco. My insurance company (also Direct Line) refused, saying I would have to pay the £250 difference, PLUS £75 excess, if I wanted the genuine LR part. Naturally I declined, opting instead to give the generic windscreen another chance after assurances from Autoglass it would be identical to the genuine LR glass just without the LR logo in the bottom corner. So, new screen fitted this week and, guess what...., the rain sensor doesn't work once again???? Autoglass are currently awaiting approval from the insurers to remove and fit a genuine LR windscreen. Meanwhile, I'm poised to fight my corner if expected to cough-up the extra just because their approved fitters supply unsuitable parts. Watch this space!!!! MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs |
Fri Sep 13 2013 12:37am |
The non-LR screen fitted by Autoglass on my RRS includes the rain sensor and it worked first time. Indeed, I had the screen replaced twice in a month because of stone cracks and on both occasions the rain sensor worked correctly.
Fri Sep 13 2013 2:27pm |
