Home > General > stereo error message |
Did you have your alternator tested at the time you replaced your battery? Common problem alternators if you've had to replace the battery. Its usually the cause of the battery failing. Is it a genuine L/R battery? |
Wed Jul 17 2013 3:32pm |
dal1557 Member Since: 30 Jun 2013 Location: Montrose Posts: 23 |
hi and thanks for your reply not to sure if its a landrover battrie but i will check when i get home ive not long bought my rrs
Wed Jul 17 2013 3:39pm |
Its critical that you get the correct battery for these sports with them having such a temperamental electrical system.
Wed Jul 17 2013 7:41pm |
Prelude Member Since: 29 Dec 2012 Location: Daan Saaf Posts: 57 |
What you need is a new battery. Its because you have a battrie that you have the problem. A battrie will not deliver as much voltage as a battery. |
Wed Jul 17 2013 11:14pm |
Just a simple question, but is the engine running when you get this message? You will always see it if the engine is not running and you turn it up loud.
Thu Jul 18 2013 8:42am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
It could always be the brake light bulbs I'd go with Bodsy's diagnosis. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Jul 18 2013 11:42am |
Did you resolve this issue |
Mon Jul 22 2013 9:53am |
no not yet am offshore til tomorrow
Mon Jul 22 2013 1:55pm |
Only the ones suggested above. |
Mon Jul 22 2013 2:30pm |
