Home > My Range Rover Sport > Alignment question |
fallschirmjager Member Since: 31 Mar 2013 Location: United Arab Emirates Posts: 22 |
If your tyres are toed out then you should have excessive wear on the inside. Have you? Any abnormal wear on tyres should be investigated and put right. |
Tue Jul 09 2013 7:07pm |
jagspete Member Since: 13 Jun 2013 Location: Valencia Posts: 165 |
thank you
Tue Jul 09 2013 7:15pm |
Yep, just get an alignment for peace of mind anyway mate. Can only be good in the long run. |
Tue Jul 09 2013 7:17pm |
oh yes sure thanks again tdv6s 2.7 2007
Tue Jul 09 2013 7:18pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Check your lower front wishbones and your rear uppers and the rear knuckle joints before you take it, if these have play in them then a wheel alignment is a waste of time until these are fixed.
Tue Jul 09 2013 8:22pm |
Thanks Flack,
Tue Jul 09 2013 9:02pm |
Simple test for the front lower arms is to drive the at about 15 mph and dab your foot on the brake if you here a knocking then the bushes are shot.
Tue Jul 09 2013 9:17pm |
Thank you Flack! tdv6s 2.7 2007
Tue Jul 09 2013 9:32pm |
Hi Flack, So we did the alignment and I have 2 front lower control arms to change at 55 000 km. We are changing them next Wednesday. tdv6s 2.7 2007 xkr 5 2010 |
Sun Jul 21 2013 4:31pm |
