Home > Technical > TDV8 resetting while driving |
My advice would be check the battery terminals RRS gone
Thu May 30 2013 9:06am |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
i h and also made it change gear better lol ad strange things going on with my old td6 and that turned out to be a faulty battery, a new one cured it |
Thu May 30 2013 9:59pm |
RRSTDV8DK Member Since: 26 Mar 2007 Location: cph Posts: 67 |
Hi
Wed Jun 05 2013 12:36pm |
check all the earth connections, it sounds like a connection issue somewhere. Remove the battery connections and reconnect, tapping gently with a rubber mallet to make sure theyre seated correctly before tightening up Bodsys Brake Bible
Wed Jun 05 2013 12:50pm |
Hi Bodsy
Wed Jun 05 2013 1:11pm |
there's some on the inside wing near the bbattery, and a couple of more important ones underneath the fusebox in the engine bay, so youd need to remove the battery and undo the nuts holding the fusebox and look down the back of there. also, check the big connector that is on one of the ecu's there, it may have corroded away. You will see it as a big plastic plug. if it's corroded the pins, you may need a new ECU as that can also throw up spurious errors.
Wed Jun 05 2013 1:52pm |
Thank you - will go searching this weekend
Thu Jun 06 2013 9:30am |
The car is at the garage
Tue Jun 25 2013 1:33pm |
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 152 |
Hi I am at solicitors stage my RRS TDV8 keeps going flat and being unable to start, JLR can find nothing wrong but car has been flat bedded away now over 5 times. It was returned on 27th as "fixed" left locked in garage and failed to start with dead battery on 29th. If needed I am going to take them to court car is a lemon. You can quote my reg Number 462 RLP Queensland Australia JLR UK know all about this car. Again, they don't know what is wrong. We need to combine to hit them this is un acceptable. My car is a MY10. SWMBO owns this car I get to drive occasionally |
Sat Jun 29 2013 10:18pm |
Hi Meccles
Mon Jul 01 2013 12:21pm |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 |
Meccles. Have you had any issues with the upper tailgate switch opening ? Mine was corroded and flattened my battery several times. Its a known fault on the forum but LR seem to know nowt about it!! SDV8 vogue SE. Corris grey and ivory leather + most of the toys. Limited edition RRS model number 0001 Gone TDV8 RR Sport. Never to be forgotten. Wife has an i8 BMW |
Tue Jul 02 2013 1:06am |
Hi Baron,
Tue Jul 02 2013 6:41am |
Garage has thrown in the towel after one week of intensive search, being very fair and only charging me a minimum of hours, but no solution.
Tue Jul 02 2013 3:06pm |
My god you unlucky bu**er. I really don't know how car dealers get away with it I,m in retail and anything remotely faulty ends in a refund or replacement Best of luck. SDV8 vogue SE. Corris grey and ivory leather + most of the toys. Limited edition RRS model number 0001 Gone TDV8 RR Sport. Never to be forgotten. Wife has an i8 BMW |
Tue Jul 02 2013 10:11pm |
