Home > Technical > How to change front diff breather valve/filter/vent |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
One of the causes of front diff failure has been the breather hose filter clogging up and not allowing the pressure within the diff to escape. This in turn causes a build up of pressure and forces oil out of the seals. This does not affect rear diff or the transmission breather hoses.
Fri Mar 15 2013 2:36pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8857 |
Do we know where the transmission and rear diff breather vents are located? Do these also fail in the way that the front diff breather does? 2012 SDV6 - it's missing a couple of cylinders
Mon Mar 18 2013 12:59pm |
Thanks Paddi
Mon Mar 18 2013 1:33pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Thanks for the info, just found this link which gives more detail http://www.disco3.co.uk/gallery/thumbnails.php?album=23952 |
Mon Mar 18 2013 1:52pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
Gearbox and transfer box breathers run along the top of the gearbox, and exit around the vacuum pump area. The rear diff breather travels up with the fuel filler pipes behind the wheelarch liner. None of these have any valves or filters on them |
Mon Mar 18 2013 1:56pm |
Thanks for the input guys - guide has been updated accordingly Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section
Mon Mar 18 2013 2:16pm |
Thanks for the info. Just need to find the vacuum pump now... Oh, and I've ordered a breather valve for the front diff. May as well fit it - might help to delay front diff seals failing... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Mar 18 2013 5:18pm |
Replaced the breather valve today. The pipe on mine appears to be a little shorter than yours so my new valve is just touching the adjacent pipes. Not ideal but, as the original valve was U/S it can't be any worse than it was. Hopefully all will be well. 2012 SDV6 - it's missing a couple of cylinders
Tue Mar 26 2013 11:36pm |
Did mine, a little bit fiddly but got there in the end...many thanks for the heads up |
Wed Mar 27 2013 11:51am |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 |
Very well explained notes taken, thanks |
Fri Dec 20 2013 5:51pm |
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 |
Did mine today and also changed the front diff oil. Grateful thanks for the write up! I did a few miles then snipped off the old breather - immediate puff as pressure released - proving it was duff. I spotted the problem a few months earlier as when changing the engine oil I noticed one half shaft seal was slightly leaking. Would not have seen this without taking the lower main cover off.
Mon Feb 24 2014 3:50pm |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 |
thanks for great info,replaced my breather and diff oil today,old breather was and diff oil was like mud,rear ones next silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Thu Feb 27 2014 5:40pm |
