Home > General > Quick Towbar question |
Kristian_TT Member Since: 31 Jan 2013 Location: Norway Posts: 7 |
No one? |
Sun Feb 03 2013 10:05pm |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 |
Sun Feb 03 2013 10:16pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Have a look at this instruction video.
Mon Feb 04 2013 4:08pm |
sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690 |
I still find mine a little difficult but you just need to ensure you twist the key correctly and use a little force. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Mon Feb 04 2013 4:12pm |
Not really as what I want to know is wheter or not you can pull the green handle out when its locked. |
Mon Feb 04 2013 4:13pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Green handle will pull out about 5mm when it's locked, thats all.
Mon Feb 04 2013 4:20pm |
as Bean has said, it will still pull out, but you will not be able to twist it (anti-clockwise) if it's locked.
Mon Feb 04 2013 4:50pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
It may already be unlocked and stuck slightly out of position so that the mechanism hasn't released the bolt in to the housing as it would be when fully fitted. The problem is that if the hook has been left in place for a while it might be corroded and feel fully fitted even if it's not.
Mon Feb 04 2013 6:21pm |
Thanks for the replys. Ok, i guess that its still locked then since ive tried wd40 several times and also a rubber mallet with no luck. |
Tue Feb 05 2013 9:16pm |
