Home > General > Vibration At Speed |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
Try balancing the wheels first and see how that goes, but check you haven't picked up and weights made of mud first or atleast road grim |
Sun Jan 27 2013 6:02pm |
braveheart20 Member Since: 04 Apr 2012 Location: leven Posts: 22 |
Hello, I have a similar problem with my 2012 rrs.
Sun Jan 27 2013 7:04pm |
We had this with a freelander once. Not that it is necessary the issue you have though Do you want to know what the solution was...a complete set of tyres, fully balanced and then again a 4 wheel alignment. 4 wheel alignment was pointless without the new tyres as the damage was done, again the new tyres were properly balanced. run your hand along the surface an see if they are rough in reverse, this may indicate something Mike 2014 Facelift Discovery |
Sun Jan 27 2013 7:46pm |
Jacobite Member Since: 20 Jan 2013 Location: Aberdeenshire, Scotland Posts: 7 |
I bought my RRS last week & found the same whilst driving home up the Motorways. A vibration coming through
Tue Jan 29 2013 8:32am |
overfinchred Member Since: 20 Dec 2012 Location: Northants Posts: 65 |
I have the same issue and have new Overfinch alloys and tyres
Tue Jan 29 2013 3:22pm |
Sometimes these vibrations that are road speed rather than engine speed can be driveshaft related.
Tue Jan 29 2013 3:45pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
When I had a similar problem, it turned out to be the rear differential which was replaced by LR. |
Tue Jan 29 2013 4:07pm |
Further update,
Mon Feb 04 2013 7:47pm |
Silvermercf1 Member Since: 24 Jul 2015 Location: Nottingham Posts: 6 |
RRS 2013 BLACK EDITION. Had the car from new, after a few months started to get vibration in the car. Head rests visually vibrating ect at about 88 - 90 mph. Eventually found we could not balance one of the rear tires. Found about 1 pint of water in the Tyre. This happened yet again some months later. The car is now 2.5 years old and the same problem is back again. It has been suggested that the water is a build up of condensation. A possible solution is to re inflate with nitrogen and re balance after removing the water. This is my next course of action. The car is still under warranty. Reported this problem on a couple of occasions to RR dealer. They say no one has ever reported this problem before. It must have happened when I put air in the Tyre. incidentally I have never put air in this cars tires, the pressures have always remaineded okay. |
Sat Mar 26 2016 6:28pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 |
Water in Pirellis has been reported previously. Do a search on here Visitor from fullfatrr.com
Sat Mar 26 2016 6:39pm |
Thanks DrRob
Sat Mar 26 2016 7:37pm |
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 |
Mine was in 2 weeks ago, water in the tyres, took then 2 days to find the fault, they told me Pirelli have now a special sealing paste to stop this happening, took me two hours to remove the black gunk for my rims, they didn't charge me, but said it isn't covered under warranty. But as a jesturevof goodwill they will do it this time. These are the original tyres P Zero MY 13 3.0 SDV6 HSE Black Edition
Sun Mar 27 2016 11:06pm |
