Home > Wheels & Tyres > FRONT 285/35/21 REAR 325/30/21 IS IT POSSIBLE???
mse
saimans wrote:
Cant say I have every come across staggered tyre sizes on the Range Rovers. Not sure why this is as the like of BMW X5s do have wider rear wheels and tyres Question
Because land rover know how to make cars for both on and off road,,,not just trying to make a road handling car? Mike
2014 Facelift Discovery
Post #360888 Thu Oct 25 2012 5:33pm
flydive
Is that why they put 20" wheels on? '08 RRS TDV8
Post #360890 Thu Oct 25 2012 5:59pm
mse
20" are ok Mike
Post #360896 Thu Oct 25 2012 7:11pm
kml4ever
Turkey 2007 Range Rover Sport TDV6 HSE Lugano Teal
I HAVE A SOLUTION!!! I LL GET THE 21 s front wheels are 9X21 rears are 10,5X21 but my tire dealer told me that ve can apply 275/35/21 size tires for all wheels and it will not make any problem.What you guys think abut this? Or a will go for FRONT 285/35/21 REAR 325/30/21 and also for this sizes of tires i m confused if they will fit my 21 inch wheels as width i need your help guys
thanks
Crying or Very sad KML4EVER
Post #370601 Tue Jan 22 2013 11:14pm
Whatever you buy, you want the same rolling circumference front and rear or you risk transmission damage.
If you want something that looks like a BMW X5, buy a BMW X5.... 2012 SDV6 - it's missing a couple of cylinders
Post #370685 Wed Jan 23 2013 5:19pm
kml4ever
the difference is about less then 1 percentage i m not sure if it will damage or not ? about the x5 believe me if i like it i ll go for it but i m really happy with my ride but the wheels is something very important to me thank for your help KML4EVER
Post #370844 Thu Jan 24 2013 4:44pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
A bit late to the party, but 5-6 years ago ran a staggered 21" wheels setup for at least a year on my 2006 Sport - before being bitten by the off-road bug... - without any issues whatsoever. My wheels (currently collecting dust in my garage), made by Cargraphic in Germany, were sized 10x21 front (ET46) and 11.5x21 rear (ET52), with 275/40ZR21 tires in front and 315/35ZR21 in back. I could have gone with a lower profile set of tires front and rear, but I wanted to preserve as much of the original comfort as possible, so I picked the beefier set. The setup looked great back then, and no trouble with rubbing anywhere, even though the overall circumference of those 21s was slightly larger than stock.
Finding 21" tires is tough, and they are usually very expensive. If I were to do it again today, I'd probably bypass the 21" size and go with 22s, much easier to find a wide selection of tires in that size.
Post #371167 Mon Jan 28 2013 4:49am
kml4ever
Thanks alot for the info and the pücs it helped me so much.i m confused about the center diff because the front and the rear will be different sizes will it make a problem? And if i go 275/35/21 for all wheels with 9x21 front and 10,5x21 rims what will gonna happen? So confused Crying or Very sad KML4EVER
Post #371202 Mon Jan 28 2013 2:06pm
umbertob
As long as the overall circumference of front and rear tires wrapped around them is the same (yielding the same number of revolutions per mile), the center differential won't care about different rim sizes and you will have no issues. You can use an online calculator to figure out if the combination of rim width and tire size you are considering will be an appropriate match for our cars. Here is a good one: http://www.rimsntires.com/specs.jsp
In your specific example, if you are getting a wider rim for the rear, you would want a wider tire to match, as I don't think a relatively "narrow" tire such as a size 275/35 would fit well over a 10.5" wide rim. You could probably go with a 315/30/21 for example, should be a good match for the fronts and stretch nicely over the wide rear wheel, giving you the look you are looking for with no adverse effects on transmission and differentials. Of course, this is assuming the wheels you are considering have the proper offsets and internal clearances for the Sport. For example, the 21" wheels I have would not fit a Supercharged Sport (with larger front Brembo brake calipers.)
Post #371224 Mon Jan 28 2013 5:34pm
kml4ever
The closest match will be like this, front 275/35/21. Rear 315/30/21 and the circumference difference will be % 0,48. Will this difference cause any problms? KML4EVER
Post #371273 Mon Jan 28 2013 10:14pm
umbertob
No.
Post #371288 Mon Jan 28 2013 11:37pm
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
But why would you want a staggered set? 91 BMW 850CSI
Post #371892 Fri Feb 01 2013 5:31pm
umbertob
For looks, what else? If there is another reason to buy 21, 22" or larger aftermarket rims for a morbidly obese SUV, staggered or not, I am all ears. Laughing
Post #372029 Sun Feb 03 2013 7:19am
