Home > Maintenance & Modifications > drivers door lock sticking |
Its a common problem on the 2006 model cars, a dealer will be about £130-£150 to fix, but your passanger door won't be too far behind going the same way which is more difficult to repair and more costly unless you have a good warranty You can lock the drivers door by way of pulling the door handle out on the outside of the car before you shut the door, at the same time as pushing the lock lever on the inside of the car then let go of the door handle and shut your door then press your remote as usual to lock the rest of the car then check to see if your drivers door has locked, it might take a few goes to master the technique |
Tue Apr 17 2012 7:42pm |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
why would the passenger side be harder and more expensive to fix 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Wed Apr 18 2012 12:12am |
^^^Because thats the one with the emergency key lock and there is more involved. |
Wed Apr 18 2012 8:02am |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 |
thanks for tip ady,works well.! more info on this common problen them.? |
Wed Apr 18 2012 12:42pm |
Wed Apr 18 2012 12:54pm |
Benidorm Mick Member Since: 27 May 2010 Location: Wiltshire Posts: 102 |
Got the same problem guys. is this something my local man can fix or is it a LR job? What part is it that goes wrong??? Thanks |
Fri May 11 2012 1:02pm |
ELD70 Member Since: 20 Jan 2009 Location: UK Posts: 163 |
Disco 3 forum has the walkthrough guide for this problem. |
Fri May 11 2012 5:10pm |
Mick, if your car has got a warranty in place then it should be covered If not, then its a job any garage will do for you but better a garage who has done them before then they arn't running away with the hourly labour charge I think a dealer will charge around £120-130ish fitted. |
Fri May 11 2012 5:55pm |
Quote from stealers £160 inc. £49 for the part and 1 hour labour. can only assume it's a 2 man job at some point otherwise that would be £110 an hour labour
Thu May 24 2012 8:38am |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
What part is it as my car has started playing up |
Tue Dec 11 2012 9:41pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
How to replace RHS door latch and/or window regulator (Door doesn't lock/unlock)
Tue Dec 11 2012 10:40pm |
Thanks |
Tue Dec 11 2012 11:07pm |
No worries - just double check the part numbers as the guides are for the disco3. |
Tue Dec 11 2012 11:11pm |
god can not believe i started this topic in april god where does time go.? when i had my problem,somebody on another topic said just leave it and it will start to work again,and guess what its started working again and had no problems since |
Tue Dec 11 2012 11:33pm |
