Home > Technical > 3c - FBH not starting |
Just checking, your fuel light is not on is it.?
Thu Nov 29 2012 11:10am |
StevoD Member Since: 01 Nov 2012 Location: Bromsgrove Posts: 42 |
Newbie to all this FBH stuff, but just to add my understanding to see if it helps (I'm sure I'll be put right if my assumptions are incorrect ).
Thu Nov 29 2012 11:16am |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
Thank is fuel, no light there. Re StevoD, you are correct and what is not working for me is the automatic function on cold weather. Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Thu Nov 29 2012 6:20pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Climate control also needs to be on for FBH to start. |
Thu Nov 29 2012 6:30pm |
It is... Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Thu Nov 29 2012 7:20pm |
I assume you have it on and your battery is ok? Mike
Thu Nov 29 2012 10:15pm |
yep Monsieur Range Rover Vogue ‘17 TDV6
Fri Nov 30 2012 11:07am |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
Is the FBH attempting to start? Like this site? Buy some RRSPORT goodies to show your support! |
Fri Nov 30 2012 11:18am |
Actually, I don't think so! Any suggestion? Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Sat Dec 01 2012 6:33pm |
So, finally, quick trip to Park Royal on Saturday morning and Rob from service sort it out. Software update available for the fbh Test run it after and all good. Big thumb up
Mon Dec 17 2012 8:22am |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
Did they charge you for the pleasure? |
Mon Dec 17 2012 10:50am |
Nope Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Mon Dec 17 2012 11:14am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Good to see LPR still carrying on with good form following JT's departure ON THE WAY: BMW F21 M140i
Mon Dec 17 2012 11:26am |
I may have to pay them a visit then |
Mon Dec 17 2012 12:46pm |
