Home > Maintenance & Modifications > Problem with key. Sometimes it doe snot ope nthe door |
Yes there is a battery in the remote and it does need to be changed...well on the new ones that dont have a key Mike
Tue Nov 13 2012 6:52pm |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 401 |
Its a 2006 RRS.
Tue Nov 13 2012 6:57pm |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 |
i thought they charged up when in the ignition |
Tue Nov 13 2012 8:41pm |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 |
They charge using an inductance loop... Wirelessly when in the ignition, the battery is a small panasonic nicad that fails after a period of time and can be changed by breaking the key open and desoldering the old battery and replacing with a new one.
Tue Nov 13 2012 9:34pm |
So if I press the third one and the trunk opens it means what?
Wed Nov 14 2012 12:35am |
It means the 3rd button has been programed to open the boot RRS gone
Wed Nov 14 2012 9:37am |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 |
It also means that the battery on the key fob is working suggesting it may be your door actuator 2011 Autobiography Santorini Black |
Wed Nov 14 2012 9:49am |
Is it a common fault? 91 BMW 850CSI |
Wed Nov 14 2012 1:47pm |
not uncommon on the older cars RRS gone
Wed Nov 14 2012 2:46pm |
OK. So is there only one actuator or in every door?
Wed Nov 14 2012 3:27pm |
Seems a fairly common problem with the door locks. See this thread and my post for a detailed link for how to do it.
Wed Nov 14 2012 3:45pm |
All my doors unlock. The problem is that when it stands overnight, sometimes it is hard to get it to open in the morning.
Wed Nov 14 2012 4:03pm |
If the third button operates the boot and the first button doesnt unlock then the battery is probably ok and the issue is a worn button or door mechanism sticking..
Wed Nov 14 2012 6:51pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
The Definitive 'how to' thread in the technical section has a link that explains how to change the rechargeable battery.
Sat Nov 17 2012 12:35pm |
