Home > In Car Electronics > Sync My Phone Each Time?
Page 1 of 3 123>
Tahoe Dave
United States 2006 Range Rover Sport 4.4 V8 HSE Giverney Green
I have a MY 2006 and each time I enter the car I have to sync (2121) my phone. I seem to recall that early on I did not have to do this. Is this the way all 2006's are?
Post #360322 Sun Oct 21 2012 4:54pm
Bodsy
Site Sponsor
Yes Dave, it needs a software upgrade. This will also give you your contacts from your phone, on your radio Thumbs Up
I can arrange for you to have yours swapped for new software Thumbs Up
I'll drop you a PM Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #360337 Sun Oct 21 2012 7:55pm
tommy-boy
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
I also have this issue on a 08MY TDV8 HSE.
But when it does sync I do get the contacts list on the radio.
So will the upgrade work for me? Or has it potentially been done due to the contacts on the radio?
Cheers 08MY HSE 3.6 TDV8 Stornoway Grey, Twisted performance cat back... and shed loads of extras!!!
Post #360363 Mon Oct 22 2012 8:30am
Bodsy
Site Sponsor
Tommy, sounds like yours already has the newer software on.
Try opening the bonnet, then letting the car go to sleep, then disconnecting the battery, touching the pos and neg cables (not battery) together for 20 secs, reconnect securely to the battery, then try it again. Bodsys Brake Bible
See it HERE
Post #360364 Mon Oct 22 2012 8:52am
tommy-boy
Ok I'll try this today and see how it goes.
So what is the purpos of this process? 08MY HSE 3.6 TDV8 Stornoway Grey, Twisted performance cat back... and shed loads of extras!!!
Post #360367 Mon Oct 22 2012 9:05am
Bodsy
Site Sponsor
It drains all ecu's of any stored power, then when you ignition back up again, they all re sync with themselves effectively.
Sometimes the modules can become confused Laughing
This works for all sorts of ecu software anomalies that occasionally blight our wonderful vehicles Thumbs Up Bodsys Brake Bible
See it HERE
Post #360368 Mon Oct 22 2012 9:09am
tommy-boy
Well just done this so I'll keep you posted if I have any further issues.
Cheers for the help 08MY HSE 3.6 TDV8 Stornoway Grey, Twisted performance cat back... and shed loads of extras!!!
Post #360411 Mon Oct 22 2012 2:05pm
tommy-boy
well i would like to say no further issues.
however went out today been driving 15-20 mins and my phone rang... not through the blutooth.
checked the phone after the call and just shows "not connected"
I had the same issues a year or so ago with the old crapphone 3GS, but i thought the 4S wouldnt have these problems.
it connects fine when i just hit "Connect" on the phone, but just wont auto sync.
Im just going to get limo black privacy glass now its easier than trying to get the blasted thing to work 08MY HSE 3.6 TDV8 Stornoway Grey, Twisted performance cat back... and shed loads of extras!!!
Post #360585 Tue Oct 23 2012 2:48pm
Bodsy
Site Sponsor
Sounds like possibly a dodgy unit then. Double check that the cables are in it properly as I had anothe customer who reported similar after I had updated theirs.
When they swapped the unit put, they hadn't put the main connector in properly, so it would have intermittent connection.
Go to your boit. On the right hand side, there is a small panel. Remove that and if you look in, you should be able to see a black box if you peer in. One large connector and one smaller connector with orange cable. Just unplug them both and reconnect them fully. Thumbs Up Bodsys Brake Bible
See it HERE
Post #360590 Tue Oct 23 2012 3:11pm
tommy-boy
ok i know where it is as i remember seeing it when i did the mod for the rear courtsey lights.
will keep you posted again.
cheers for the help!!! Bow down 08MY HSE 3.6 TDV8 Stornoway Grey, Twisted performance cat back... and shed loads of extras!!!
Post #360592 Tue Oct 23 2012 3:20pm
happs
2005 Range Rover Sport TDV6 HSE Java Black
Snyc my phone
Hi i have a 2005 RRS and wanted to know how to update the software so i dont have to keep putting in the code 2121!
Can anyone help me please
Thanks
Happs
Post #367806 Thu Dec 27 2012 11:38pm
Bodsy
Site Sponsor
I can help Happs. Thumbs Up
Ill send you a PM. Thumbs Up Bodsys Brake Bible
See it HERE
Post #367821 Fri Dec 28 2012 9:47am
skilachi
Hi Bodsy,
I need the same to be done on my RRS 2005 but I'm based in London.
Do you know of any contacts in London area?
Thanks
Post #400639 Thu Oct 31 2013 10:58am
Bodsy
Site Sponsor
As the other post, I can provide a postal service fix for this. Will message you shortly. Thumbs Up Bodsys Brake Bible
See it HERE
Post #400661 Thu Oct 31 2013 1:47pm
tanloverluke
could you also please let me have some info on this Bodsy, thank you Thumbs Up Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #400671 Thu Oct 31 2013 3:06pm
Page 1 of 3 123>
