Home > Photos, Videos & Media > In-car camera files
Page 3 of 12 <123 4 ... 101112>
A little bigger than I anticipated Confused ON THE WAY: BMW F21 M140i
Post #360191 Fri Oct 19 2012 10:20pm
Cheers Nick, any idea which accessories i will need to buy for my requirements above Question i'm hoping muddy will be along soon to give me an idea. It looks like i need to be a member on the gippo site too Laughing
Post #360192 Fri Oct 19 2012 10:26pm
muddywheels
Milk Float Man
I ordered the 400 v2 - supposed to be the best but it is grey - some on disco have sprayed theirs black but not decided if I will yet Confused
I always park in well lit/public areas, with cctv if possible, have laminated glass and double locked with internal sensors armed so not sure if anyone would attempt to steal the camera - I think they would draw too much attention to themselves Thumbs Up
I went for the power saver for the RRS and spare holder/power lead for the mini which will be used abroad when I hire a car in future Cool
I put the socket from the power saver in the glovebox so I can unplug the lead if parked in the garage and connected with piggyback fuses http://www.ebay.co.uk/itm/2-X-MINI-FUSE-AD...0367943245
Yellow permanent supply lead - fuse 48 - Trailer connector (battery feed)
Red switched supply lead - fuse 52 - Cigar lighter
Black to earth screw on metal
I will take a pic when I can Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #360193 Fri Oct 19 2012 10:35pm
Not sure, lots of info on d3
Wiggs seems to be knowledgable chap, pm him on here to save joining up there?
Post #360194 Fri Oct 19 2012 10:36pm
Many thanks guys, it looks like i will have to have one of these cameras. Thumbs Up
Post #360195 Fri Oct 19 2012 10:49pm
big pimp
I've had one of them from the first group buy on disco3.
They are a fantastic piece of equipment. I think I'm gonna get another one for the workvan too. I didn't get the standby thing though - might be handy to add it in, any pics of the installation of the standby unit mate MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #360198 Sat Oct 20 2012 12:19am
@muddy
Can't say I'd have been too worried by the situation in the OP. Sure, he pulled across you but he started to do so when you were still a little way from the junction - i.e. you weren't to his right on the roundabout. One might suggest he was a little quick to pull out but then one might also suggest you were approaching a bit quickly based on the fact there are two cars to your right, either of which might have turned across you (particularly the first one which got to the r'about at about the same time as you did). I'd have probably given a little toot on the horn as I passed behind the hatchback - perfectly reasonable use of the horn as you're informing another driver of your presence on the road.
This seems to be one of those "felt bad at the time" incidents that, with hindsight, probably wasn't that bad.
Having said that, the golden rule is that one shouldn't carry out any manoeuvre that makes another driver feel he needs to take avoiding action. In this case you probably felt that way so the hatchback driver was a bit naughty if not actually that dangerous.
Just my view of a snapshot video of a fairly typical roundabout incident.
The camera's output, however, is first rate. I've been thinking of installing something similar and this has certainly provided food for thought Bow down 2012 SDV6 - it's missing a couple of cylinders
Post #360199 Sat Oct 20 2012 12:39am
Kensta
I want one of these cameras they look great! Problem with me is I'm in my work van more than my RRS but wud want to use it in both vehicles is this possible to switch it between both vehicles or do I have to buy two systems ? Question Java black 2006
Post #360208 Sat Oct 20 2012 9:23am
muddywheels
Milk Float Man
I purchased additional holder and power lead and swap bv between mini and RRS Thumbs Up
I only got one power saver for the RRS though because that is my main vehicle and trying to sell the mini - so only videos in RRS when parked Embarassed Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #360211 Sat Oct 20 2012 9:31am
Kensta
Thanx muddy! Looks like they r worth there weight in gold Java black 2006
Post #360215 Sat Oct 20 2012 9:53am
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Have had mine for about a year.Checked playback after a 40 ton truck pulled infront of me....on a roundabout with near dire
consequences......found the last recorded file was dated 20/08/12 ....looks like the card has died and is not recording.
Tried updating pittasoft ware but still wont work although "She" says the usual welcome on start up.
Shall buy another card and try again.I dont find it "plug and play" so advise anyone to consider this before purchase! Neutral
Post #360265 Sat Oct 20 2012 8:07pm
muddywheels
Milk Float Man
According to the instructions you need to reformat the sd card regularly and check for firmware updates Confused
Mine had a wobbly yesterday and kept restarting and telling me to check sd card - I disconnected and then plugged it back in and it appeared to sort it Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #360355 Sun Oct 21 2012 10:27pm
whippetman
That is the problem......tried to reformat the card twice and downloaded the latest software but it really is quite geeky
not like using a Video camera not plug and play.Looks like another 2 hours of hit and miss on the pc to get it going again .
Korean pijin english doesnt help too much either Sad
Post #360358 Mon Oct 22 2012 12:08am
So are they proving to be a little bit unreliable then these cameras? Whistle
Post #360365 Mon Oct 22 2012 8:55am
flydive
Whippetman
What are you using to format the SD card?
You should use the sd formatter software that you can download from Pittasoft site. '08 RRS TDV8
Post #360369 Mon Oct 22 2012 9:11am
