Home > Maintenance & Modifications > gearbox oil change |
I was warnewd not to use anything other than LR approved ZF Lifeguard
Thu Sep 27 2012 1:41pm |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
Are nt these gear boxes sealed for life? |
Thu Sep 27 2012 1:57pm |
100k service I think. RRS gone
Thu Sep 27 2012 3:13pm |
Mike767 Member Since: 31 Aug 2012 Location: Cheshire Posts: 19 |
There is a load of information on this subject over on the D3 site. Supposedly sealed for life, but lots of reports of gearbox shudder under load. I assume the same box is fitted to the RRS 2.7, but I'm a new RRS owner.
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 |
hi I changed mine myself
Thu Sep 27 2012 9:02pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
Gearbox oil is recommended at 150k/10 years, but well worthwhile replacing at 75k. Also consider erplacing the sump/filter assy at the same time.
Fri Sep 28 2012 5:51am |
LR are always a good source of duff information " .....I was told from LR was good as a lot of oil stays in transfer box ". Well it would wouldn't it since the transfer box is a separate unit with its own oil of a different specification?
Fri Sep 28 2012 12:40pm |
The old sump does not need to be broken to be removed. The transfer box needs raised, and the O/S engine mount needs unbolted and the engine raised up, but it does come out
Fri Sep 28 2012 12:50pm |
Mike 2014 Facelift Discovery |
Fri Sep 28 2012 4:39pm |
The Britpart kit uses a Genuine LR sump pan, and ZF Lifeguard 6 fluid.
Fri Sep 28 2012 6:17pm |
Pearls of wisdom Disco Mikey; much appreciated - is it the same for my TDV8?
Fri Sep 28 2012 6:28pm |
Never done a TDV8 yet.
Fri Sep 28 2012 7:07pm |
If thats the case, then - never been a britpart part that i would trust in a sensitive area Mike 2014 Facelift Discovery |
Fri Sep 28 2012 7:45pm |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 |
Thu Oct 04 2012 1:08pm |
