Home > Off Roading & Green Laning > Does a G4 need any additions to protect/improve it offroad? |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 |
No, not really. You may want to consider a 2nd battery setup and it should still have the UHF radio power lead & speaker in the top glovebox, so it's not difficult to add one of those if you want. Look for the Traxide kit if you want a 2nd battery, it's a plug & play setup designed for the D3/RRS. Also helps to extend the life of the main battery.
Thu May 10 2012 1:29pm |
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 |
Thanks Mike! Didn't realise they had UHF radio wiring, where is the antenna?
Thu May 10 2012 5:20pm |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
it contains the filter
Thu May 10 2012 11:14pm |
I see! The car has done 60k miles, so a full service, full fluid and filter change will be on the cards in the next month or two!
Fri May 11 2012 10:09am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
You'd need to use an EAS module to alter the standard ride height to be the same as off road, I think.
Fri May 11 2012 10:24pm |
That sounds cool! Although I want standard height to be standard, but if it has multiple settings that should be fine.
Fri May 11 2012 11:19pm |
If you know Stuart then give him a call for your Sport and mention my name, he'll see you right with anything you need sorting It's my car on the front page of his website, he's looked after it like his own. In all seriousness he pretty much rebuilt mine and then took it down to the docks for me, he's a real good friend.
Sat May 12 2012 12:28pm |
Thanks MikeS, as ever!
Tue May 22 2012 1:35pm |
