Home > General > Access Mode
p3smith
Access Mode
Hi all,
Can anybody tell me how much the height of a 2006 RRS supercharged is reduced when access mode is activated?
Still continuing with my garage measuring and looks like I need to hire a sport for the day to be completely happy and sure!
Finally, the official height of the 2006 model is 1816mm but the land rover official site shows the current RRS with a height of 1877mm. Is it true the current model is taller than the 2006 model?
Thanks guys
Post #339809 Fri Apr 13 2012 10:14pm
I think access mode lowers the car by 50mm
The 1.816 is in access mode from floor to top of sat nav antenna
I don't think the new car is any taller no RRS gone
Post #339811 Fri Apr 13 2012 10:25pm
p3smith
Many thanks for reply.
So I'm a little confused now. The official Land rover site states The following:
Height: 1877mm (this figure is different from all other sources, that being 1816mm which is why I asked earlier is the new RRS taller than the 2006 model I'm looking at buying)
It has an asterix denoting †Access height air suspension setting reduces height given by 50mm to 1,739mm.
None of this makes sense to me unless I'm being really thick Confused
My garage door aperture is 1830mm which is why I'm sounding a little obsessive! Don't want to make an expensive mistake!
Post #339825 Fri Apr 13 2012 11:33pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
Paul, - I have an '06 model Supercharged which fits in my "standard size" garage with an up-and-over-door. I did have similar concerns to you before buying.
Mirrors need to be folded to get through the aperture but once inside the garage, enough room to get in and out, - and raise the bonnet with a little room to spare below the open (and raised) garage door.
I make a point of reversing into the garage and parking the offside as close to the wall as possible then get out / in through the passenger side door. That way if the remote should ever fail I figure that i can still access through the manual lock in the passenger door.
I'll take some measurements of the garage door tomorrow and let you know what size.
Hope this helps. Carl
Post #339829 Sat Apr 14 2012 12:44am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
do you park in your garage frequently? getting in/out through the passenger size sounds like a bit of a ball-ache? Shocked ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #339844 Sat Apr 14 2012 9:31am
Vasquez
United Kingdom 2009 Range Rover Sport Supercharged Bonatti Grey
My Supercharged also fits nicely in the garage in access mode Very Happy If it doesnt scare you it isnt heavy enough
Post #339932 Sun Apr 15 2012 11:51am
1.83 garage door height you will be fine Thumbs Up RRS gone
Post #340027 Mon Apr 16 2012 9:05am
p3smith
That's great - thanks!
Post #340124 Mon Apr 16 2012 10:17pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
I disagree.........it sounds like a huge ball ache Mr. Green
 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #340134 Tue Apr 17 2012 7:42am
V8SC
Laughing - It really not a problem guys, -and much less of a ball-ache than the dreaded remote failure might be when the only manual key access point is through the passenger door Wink
Thumbs Up Carl
Post #340569 Thu Apr 19 2012 9:58pm
