Home > Technical > Placed jack in wrong location |
Very common to damage the compressor - do a search and you will get an idea of price Mike
Mon Feb 06 2012 11:11pm |
Katrina999 Member Since: 23 Sep 2011 Location: Ayrshire Posts: 13 |
can't find anything in the search to say whether it's safe to drive or not ?? anyone any idea or should I get it recovered ? I did drive it today and the compressor sound came on when I first started the car not every time but lasted about 1 minute then went off again... Katrina |
Tue Feb 07 2012 12:17am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
I did the same a couple of weeks ago - sounds as if the compressor is all OK and working as it should - the air compressor is just topping up the air tank and will most often do it for a while on start up . The reason you can here it is because it is most likely the mount is damaged and the insulation cracked - should be OK to drive but it need to be checked and fixed quickly.
Tue Feb 07 2012 12:44am |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
The compressor is attached to the car by an alloy bracket which almost always snaps under the weight of the car if used as a jacking point.
Tue Feb 07 2012 7:14am |
yep bracket is knackered and it seems one of the pipes has gone too so it will be in next week to be fixed guy told me not to worry hazard of owning RRS lol... but it's not the end of the world. He is going to take one of an old compressor and place it on ours so hopefully the bill won't be too bad. Thanks to all that replied hubby still in the dog house Katrina |
Thu Feb 09 2012 1:14am |
