Home > Technical > Tyres and spare question
stuart j
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bourneville
Collected my TDV6 RRS 3.0 on Friday, absolutely delighted with it – but one question re tyres, please.
The 4 on the car are 20” diameter with 275/40/20 tyres, but the spare is a 19” with 175/80/19 tyre – the dealer says this is standard as the rolling radius of the spare is very close to that of the main four wheels, but I’d have expected the 5 to be identical.
Anyone actually used a spare akin to this to confirm all is well, please?
Many thanks,
Stuart
Post #330137 Mon Jan 30 2012 12:13pm
Yes, daft as it sounds, that's correct. Thumbs Up
On my new MY12 RRS, I have 20" wheels on the car and a 19" wheel spare.
You can if you choose to, buy a similar spare 20" and store it in the same place, instead of the current 19", but it will protrude slightly under the car a little more and change your 'exit angles' should you choose to put it through its paces a little off road.
HTH Smile ON THE WAY: BMW F21 M140i
Post #330138 Mon Jan 30 2012 12:17pm
Jimmy_75000
same here as well Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #330140 Mon Jan 30 2012 12:27pm
chesterfield
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Eh? That 80 profile looks wrong to me.
a 175/80 R19 has a diameter 35mm larger than that of a 275/40 R20. Its rolling radius is almost 5% out.
A 175/70 R19 would be an exact match for the rolling radius. RRS 3.0D HSE 11MY - Fuji White, a few extras.
Post #330141 Mon Jan 30 2012 12:41pm
Will check my profile tonight and report back Confused . I know its a 19", but not sure what the others details are Embarassed ON THE WAY: BMW F21 M140i
Post #330147 Mon Jan 30 2012 12:55pm
essexfarmer
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
Just had a look under mine to save beancounter getting dirty Very Happy and the 80 profile seems correct
My tyres are 275/40 R20 Contis on the car and a rubbish 175/80 R19 space saver thing underneath.
I keep meaning to treat myself to a full size spare, I wanted one when I ordered the car but was told this is no longer an option, not sure if I beleive that.
If you still want a full size spare Stuart, ebay is a good option. 12MY RRS Orkney Grey HSE Lux
12MY FF Santorini Black VSE
Post #330152 Mon Jan 30 2012 1:29pm
stuart j
Excellent speedy responses, thank you all – agree with Mr Chesterfield’s view that while the spare wheel and tyre look pretty robust (unlike a spacesaver), the rolling radius appears to be 3.5 cms. too big, so have asked the dealer to clarify – will let you know their view. Presumably the air suspension wouldn’t compensate for one bigger wheel?
Great forum, as good as the RRS !
Stuart
Post #330154 Mon Jan 30 2012 1:34pm
Thanks EF Thumbs Up
Of course, wouldn't have been me getting dirty, oh no, one of the staff dear chap Whistle Rolling with laughter ON THE WAY: BMW F21 M140i
Post #330156 Mon Jan 30 2012 1:38pm
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
175 80 19. = standard issue for those with 20inch alloy!!
Post #330159 Mon Jan 30 2012 2:47pm
chesterfield
I would have thought the larger rolling radius would have played havoc with the traction control systems as one wheel would have been rotating at a faster rate than the other in all sorts of conditions.
Maybe the pressure or sidewall strength on the spare are lower and allow for more compression, therefore equalling the rolling radius out?
I know after looking at getting a set of winter wheels and tyres, the specification in the handbook shows a differing profile for winter tyres, Im assuming more compression in the rubber counteracts the extra profile height. RRS 3.0D HSE 11MY - Fuji White, a few extras.
Post #330160 Mon Jan 30 2012 2:47pm
whippetman
That clever stuff is all beyond me but the sidewall of the spare states "INFLATE TO 60 psi"
So perhaps that solves the equation Confused
Post #330186 Mon Jan 30 2012 7:06pm
Supacat
Are you sure that the wording does not include the word maximum as in don't inflate any higher than this?
Post #330268 Tue Jan 31 2012 11:33am
whippetman
No!
"INFLATE TO 420 K.P.A. (60 PSI)"
Mine is in the cellar and easy to read Very Happy
Post #330298 Tue Jan 31 2012 2:15pm
Mike waldie
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Get a wheel protector for your spare otherwise at some point it will go walkies!!!!
Post #330299 Tue Jan 31 2012 2:17pm
whippetman
Good advice and I have mine on the full size alloy.
C'ant really understand why they nick the space savers unless they sell them to the V.W. van owners??
Post #330302 Tue Jan 31 2012 2:31pm
