Home > Technical > Entry/Exit - seat move? |
V8V Man Member Since: 12 Jan 2011 Location: Reading Posts: 65 |
You raise an interesting point as I also own a MY11 HSE and on most occasions the steering wheel and seat do move to I guess what is called the "access mode" However, on some occasions the seat and steering wheel move a great deal more in that if I open the door and stay seated I am left in a significant recline!
Wed Nov 16 2011 12:02am |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
I've noticed the same myself (after philmw mentioned it) and wonder if the seat not moving is related to its position being stored in memory, rather than the seats last position. Must try and set the memory and see if the seat and steering wheel both move. |
Wed Nov 16 2011 1:32am |
essexfarmer Member Since: 28 Aug 2011 Location: Essex Posts: 108 |
I find with mine that the steering wheel only moves up a fraction because I have it nearly all the way up anyway and the seat does not move at all because I need it all the way down while I am driving to get enough headroom. It's a good idea in theory but it's just a shame the wheel does not retract like it does in the FFRR. 12MY RRS Orkney Grey HSE Lux
Wed Nov 16 2011 6:46am |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
I never managed to have the seat to move.....Only the steering wheel does.... If anyone has an answer...!!!! Range Rover Vogue ‘17 TDV6
Wed Nov 16 2011 9:45am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
^^^ Exactly the same here
Try putting the seat up higher , then switching the car off. The seat should then drop to a more accessable height. ON THE WAY: BMW F21 M140i MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ) GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
Wed Nov 16 2011 10:19am |
nope.... Range Rover Vogue ‘17 TDV6
Wed Nov 16 2011 4:42pm |
Silly question I know, but do all models have the seat movement aswell as the steering wheel ?
Wed Nov 16 2011 4:54pm |
Mr H Member Since: 09 Sep 2011 Location: Lincs Posts: 427 |
It moves both the wheel and seat on my model
Wed Nov 16 2011 7:38pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1667 |
Thanks all. Getting somewhere - the seat moves down (at the rear) on exit if raised - my normal position is fully down anyway so hadn't noticed. |
Wed Nov 16 2011 11:17pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
As others report, It can only lower the seat if its in a high position . It also depends on which one of your 2 remote control keys you are useing itisme |
Fri Nov 18 2011 2:44pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Check the position of the Electric column switch, is it set to Auto ???? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri Nov 18 2011 2:47pm |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5584 |
The only time my seat moved was when I knocked the door controls by accident - pinned me to the wheel Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Fri Nov 18 2011 3:02pm |
The seat and steering wheel move relative to the normal set position you have them to eg, if them moving doesnt give you more room then it wont.
Sun Nov 20 2011 7:18pm |
rr5port Member Since: 08 Jun 2011 Location: Northampton Posts: 43 |
Have you stored your driving position into 1 of the 3 memory?
Tue Nov 22 2011 11:20am |
