Home > Technical > Adaptive Headlights not dancing |
Nice But Dim Member Since: 15 Oct 2010 Location: Kent Posts: 61 |
I have a 2006 S/C and i have seen them do the dance twice in the six months i have owned it, i was wondering the same, do i have a fault, interested to see if any knows if there is a specific way the lights need to be switched on. --------------------------
Sun Jun 26 2011 12:17am |
That's the Adaptive Front Lighting System (AFS).
Sun Jun 26 2011 2:21am |
robmeister1969 Member Since: 24 May 2008 Location: Surrey Posts: 125 |
Thanks Bobby. The test you suggested is exactly what I had done last night before posting.
Sun Jun 26 2011 6:02am |
Yes, engine warning light should not be related to this although the AFS could be affected if there is a problem with the suspension system.
Sun Jun 26 2011 2:27pm |
I've thought to myself that perhaps the lights only go through the calibration routine if the car has been moved? On Saturday Id started the engine a couple of times without looking at the lights and then when I was looking for the 'dance' in the evening, I hadn't driven anywhere. Will check once it gets dark tonight. |
Mon Jun 27 2011 2:10pm |
Just wondered if anyone has come across this issue since my original post? |
Tue Aug 06 2013 4:40pm |
JS3 Member Since: 26 Nov 2013 Location: Yorkshire Posts: 24 |
I am experiencing something very similar, only that one side does not dance.
Mon Dec 02 2013 9:00pm |
Yes, but I don't think it's the same issue if you have one side working.
Tue Mar 11 2014 8:03pm |
Thanks - and yes still having the intermittent fault. It seems if I switch on the lights whilst the car is not level (i.e. on a slope) both sides work fine. Which leads me to think that a level sensor could be sticky and needs free-ing up.
Wed Mar 12 2014 10:04am |
japaaa Member Since: 04 Oct 2013 Location: Sao Paulo Posts: 4 |
My AFS is not dancing either. I've found this part number 5DF008704-70 but haven't changed yet.
Wed Oct 22 2014 12:49am |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
Mine don't dance either. was it a standard feature on all cars? Mines a 55 plate. I'm guessing it was as there's no manual option.
Wed Oct 22 2014 3:53pm |
pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 41 |
I have the same problem, my lights are not dancing.
Mon Jan 12 2015 5:46pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8847 |
The CJB is the Central Junction Box and is behind the lower glovebox - you have to drop the glovebox down and release the sides to get to it. The BJB the Battery Junction Box is next to the battery in the engine bay.
Tue Jan 13 2015 12:22am |
Thank you for a fast answer.
Tue Jan 13 2015 1:45am |
