Home > Tips & Tricks > Is it possible to lock MY10 when running? |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 |
As title says really - is it possible to start the rrs, get heat etc running, and lock it and keep the keys in my pocket?
Thu Dec 23 2010 11:49pm |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 |
No i dont think there is....................so i just leave the missus sat in there while its defrosting MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers
Fri Dec 24 2010 1:15am |
RichardM Member Since: 25 Sep 2009 Location: Herts Posts: 745 |
I do it by starting the engine, lowering the drivers window, get out and shut the door, press the lock button by putting your hand in through the window, car will lock, then lift the window up button withdrawing your hand quickly! Car will be all locked up and secure. As long as you have the key you will be able to open the door as usual. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Fri Dec 24 2010 8:48am |
Brilliant Richard - good thinking!
Fri Dec 24 2010 10:56am |
I remember that well from my 335! Its easier on the RRS as you don't have to start and then stop the engine. In the Alfa I have to do the same as the RRS except to start it I have to hold the key near to the ignition (but not press it in as your supposed to). Amazing what you find on owners forums. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award 2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys 2009 TDV6 3.0 HSE Buckingham Blue - GONE |
Fri Dec 24 2010 12:18pm |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
forgot about this tip till the other day when i had to stick my car on the road to take my wifes car out of the driveway at 5 in the morning - smugly put the window down, locked it then put window up. came back to it , pressed the unlock button and it just went , beep beep and now doors would not open. F k!!! i then started to panic, and tried to use the tailgate open button on the fob. nothing!!. i then wondered how long the car would idle on a full tank......then realised i could manually open it with the emergancy key. managed to prise the handle off by the light of my phone and gained entry , phew!! this tip does NOT work on a 2010 SE!!! cheers dave MY10 TDV6 SE (debadged ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps! Gone: a comprehensive list of imprezas and a Merc ML AMG |
Thu Jan 27 2011 12:26am |
Do you not have keyless entry? WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Thu Jan 27 2011 9:17am |
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 |
Richard.....you never told me, how come the RRS has gone?? Whats replaced it? How is the Mito going? |
Thu Jan 27 2011 9:19am |
no, the Se hasnt got keyless - must be why i couldnt get in.
Thu Jan 27 2011 10:47am |
It definitely works on a car with keyless entry. Glad to hear you weren't locked out completely.
Fri Jan 28 2011 12:08am |
