Home > Technical > Tbh heater fumes in cabin
sworks
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Galway Green
Can anyone help here I suspect I am getting fumes inside the cabin when idling have had a stinking headache and can smell fumes inside
Slightly worried about this has anyone else noticed this issue
Post #283265 Fri Dec 17 2010 9:40pm
muddywheels
Milk Float Man
I have smelt this first thing when manoeuvring i.e. turning around/reversing but disappears when I set off Neutral Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #283286 Fri Dec 17 2010 11:15pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Not a lot can be done apart from putting your 'recirculation' button on when idling... It's a flaw of the FBH not venting out of the engine bay...
Jump in start the car and hit the button for recirculate. Should stop it... Also anything over +5 deg won't activate the FBH....
Alex
Post #283318 Sat Dec 18 2010 10:07am
Bradders
Me too; while sat in traffic. It seems to go once the car is moving again. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #283330 Sat Dec 18 2010 11:59am
wackyjim
Scotland
Also check there is not an actual diesel leak from the high pressure fuel pump or a leaking injector which is spraying onto the manifold....it can give similar fumes and as it evaporates once it hits the manifold there are no real tell tale drip signs below the car
Post #283354 Sat Dec 18 2010 2:28pm
sworks
Thanks very much for the feed back does the FBH (my error) keep on running when the engine is switched I know it runs when the engine is off
One thing I did think that was hampering the exhaust was the build up of snow within the arches
But will certainly lOok at the HP fuel manifold for leakage
Post #283437 Sun Dec 19 2010 12:32pm
