Home > Technical > HDC Fault, Transmission Fault, Special Programs Off |
More than likely a low battery or corroded terminals... coupled with cold weather = HDC fault...
Wed Dec 15 2010 10:34am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 374 |
Mine does HDC fault every morning but starts and works fine. I think the battery wont charge past a certain level because if i boost it then HDC fault goes away until the next day when the battery has drained slightly.
Wed Dec 15 2010 2:00pm |
Most likely to be an aging battery but also check that all the lamps (especially the brake lights) are working because a failed lamp in the rear clusters can also throw the systems into spurious alarms. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Dec 15 2010 2:06pm |
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 |
I had the same faults coming up, new battery cured it for me Cheers Paul
Wed Dec 15 2010 9:37pm |
Johnny15 Member Since: 14 Dec 2010 Location: United States Posts: 2 |
Well, the dealership says I have a bad transfer module ($578.00). Hope they are right. Thanks everyone for the quick responses. |
Thu Dec 16 2010 5:10pm |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
Hmmmmmm! Sounds like battery. If it was me I'd change the battery as it doesn't have that much life left anyway. |
Thu Dec 16 2010 5:34pm |
