Home > Technical > Outer/inner edge tyre wear? |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 |
I may be the odd one out here. Running Goodyear wranglers - fronts replaced due to punctures at 30k ish. showing only half worn.
Wed Nov 17 2010 1:49pm |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
Bloody hell, I've done almost 33k in mine and 2nd set of front tyres are 3/4 worn and all the pads (2nd set) are ready for changing again!
Wed Nov 17 2010 8:01pm |
wackyjim Member Since: 12 Nov 2009 Location: Tayside Posts: 265 |
Me too!!! 11000 miles and the Conti's are gubbed...best I get is 19mpg!!! and all I seem to read about is other RRs drivers getting nearer 30mpg!!! I don't drive like a maniac either so I feel like I must be doing something wrong!!! Or maybe I'm just less economical with the truth!!! |
Wed Nov 17 2010 9:49pm |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 |
Agree with Hugh Haddow, I have Goodyear Wrangler F1's...... done 23k now and all four tyres still have between 5 -6 mm of tread left with no sign of uneven wear front or back.
Wed Nov 17 2010 10:04pm |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 |
Well, even LR blames them. '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Wed Nov 17 2010 10:12pm |
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 |
I had Pirellis on my RRS and at 9000+ miles there was no real signs of wear on them. Have heard of guys over on the VCUK forum having the same problem with Contis on the XC90s so it's not a characteristic exclusive to the RRS with them. The X5 is on Bridge stones and heading for 10000 miles now with a wee bit of wear started on the outer edges but I had a 4 wheel alignment done and they said it was out a bit so that should be it cured! Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
Thu Nov 18 2010 12:36am |
Moonroof Member Since: 21 Aug 2010 Location: N. Ireland Posts: 9 |
No point in blaming the tyre manufacturer, more likely it's the wheel alignment that's out.
Sun Nov 21 2010 9:53pm |
