Home > Maintenance & Modifications > Missing part or not?
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Started using the AUX out option on the rear of the mid console, for my MP3 music.
This is when i found out that there was a neighbouring power outlet socket, which is empty.
Is this the standard config or should there be an cover plug installed or another sigaret lighter?
Always like to keep my car compleet.
Thanks!
SW
Post #238604 Thu Oct 01 2009 12:29am
crowej
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
nope thats standard
Post #238605 Thu Oct 01 2009 2:27am
MAW
Confused I had a power socket in my HSE next to the Aux....
Post #238618 Thu Oct 01 2009 7:11am
Alias
Switzerland 2006 Range Rover Sport TDV6 HSE Java Black
Me too. Also in my HSE TDV6. But my power outlet socklet in the front doesn't work. Wink
Post #238624 Thu Oct 01 2009 7:36am
You should have power next to the AUX port on an HSE... mine did and was one of the earliest models.
Post #238625 Thu Oct 01 2009 7:40am
SkyWalker
I'm sorry for my imprecise message.
-The power socket is there and works.
The thing is: it's empty. Should there be a protection plug like in the trunk (against dust and little childeren fingers) or a second cigar lighter installed?
-Second thing is that the lid of the ash tray in the front won't stay closed...EASY FIX?
Thanks.
SW
Post #238633 Thu Oct 01 2009 8:06am
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
No SW, mines just empty don't you have a cover that covers the aux and 12 v sockets?
Hadn't thought of the rear 12v socket needing a cover, especially to stop kids fingers getting in there.
Suppose 12volts on wet fingers would only produce a tingly feeling. Could be a competitor for rear DVD screens in keeping kids amused on long journeys. Whistle
Dunno about the front ashtray cover, mine has it's moments when it wants to open up when you close it. But it normally does what you want at second attempt. Maybe the gubbins inside have given up?
Post #238682 Thu Oct 01 2009 12:06pm
ViewWise
yea it doesnt come with a cover because theres a slide down one that covers the aux and the socket. Obviously noone gave though to the issue of it always being open if you use aux on the regular. I keep my iphone charger in there 24/7. WINNER - 2008 Best All New Photograph
WINNER - 2009 Best All New Photograph
Post #238687 Thu Oct 01 2009 12:25pm
MAW
IIRC i had that also - not sure if the Wink means you are jesting Question IIRC it is fused along with the headlamp washer jets - they working ? I put it down to a frozen tank in winter and an attempt to use .....
Post #238748 Thu Oct 01 2009 7:53pm
Alias
I will ask my local dealer. Next week I had to go for my last warranty check up.
Post #238750 Thu Oct 01 2009 8:05pm
SkyWalker
Found it!!
http://cgi.ebay.co.uk/Genuine-Freelander-2...563d8ce2eb SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #270374 Mon Jul 05 2010 2:20pm
