Home > Maintenance & Modifications > How to replace side vents |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
Here you go, very easy
Fri Jun 25 2010 3:06pm |
shrekrover Member Since: 25 Jun 2010 Location: INDIANA Posts: 8 |
Thank u so much ,but I see the OEM vent has a projection in the back ,while the chrome vent I bought to install is just a flat piece |
Fri Jun 25 2010 3:14pm |
The vent you see in the picture is the vent that is connected to the air intake, their is only one vent as shown the 2nd vent has no protrusion and is flat, you may wish to provide some photo's so we know what you are trying to fit |
Fri Jun 25 2010 3:25pm |
Fri Jun 25 2010 3:53pm |
I would just replace like for like, not sure if there would be any issue with the one not being identical to the intake side. Give it a try |
Fri Jun 25 2010 5:04pm |
thanks for your help ,actually I just started the return process ,as I am afriad to tamper with it ,as both side vents I purchased evidently have no air intake unit and it must be so risky to leave the car with no air intake unit . |
Fri Jun 25 2010 5:31pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Shrekrover The side vents on your sport actually unclip and come fully apart so you may be able to take the vent path off of the old unit and fit it to the back of your new chrome one. I'd check before returning them. This was what I had to do when I bought a set of colour coded ones for my previous 2007 model. The unvented one should also have a blanking plate on it, which again, you just transfer from the old unit currently on the car. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Fri Jun 25 2010 5:49pm |
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 |
well done Shrekrover, right forum now purple people eater
Sat Jun 26 2010 11:35pm |
