Home > Maintenance & Modifications > Parking sensors screaming!!! |
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 |
Ive had exactly the same problem with mine. I wiped them, washed them the lot to make sure they werent frozen etc and they still kept beeping. Dealer couldnt find a fault with them even though it did it in the forecourt and I went and got them out while it was doing it. Now its stopped and hasnt done it for weeks. 1 of those LR "features" I doubt..... Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
Wed Feb 24 2010 5:35pm |
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 |
Mines in the local main dealer at the moment, Back bumper is off awaiting new sensor.. Should get it back tomorrow morning Cheers Paul
Wed Feb 24 2010 8:07pm |
Just got it back form the dealers, new sensor fitted and working correctly again..
Thu Feb 25 2010 5:19pm |
RRSSTEVE Member Since: 17 Jan 2010 Location: POOLE DORSET Posts: 15 |
to test pdc sensors switch ignition on, engine off,select reverse gear if you then put your ear to sensors in turn you should hear a faint but audible clicking. if the light inside flashes there is a fault with the system either a sensor or wiring damage. |
Sun Feb 28 2010 4:09pm |
shuzzy Member Since: 02 Aug 2009 Location: West Yorkshire Posts: 143 |
Had nothing but grief with my parking sensors. First time it went in it needed a new sensor, a month later it needed a new wiring harness front and rear as it has chaffed some and shorted. Total spent so far £260! I hope thats the last of it. |
Tue Mar 02 2010 12:59am |
Ouch! Lets hope yours is now trouble free Cheers Paul 2006 TDV6 HSE - Cairns Blue Tow Pack, Privacy Glass, PTI, DVD. |
Tue Mar 02 2010 5:40pm |
stiben Member Since: 28 Feb 2010 Location: Kent Posts: 30 |
Hi all. I'm having a complete mare with mine too. They are totally clean and I'm sure one of the sensors are faulty. Does anyone know if I can buy a single sensor and fit it myself? I think i may know which ones gone because it's got a slight indentation on it. Would that cause the front not work either?
Mon Mar 08 2010 11:18am |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 |
"If a parking aid system fault has occurred, the parking aid module will relay the occurrence of the fault to the driver in the following ways:
Mon Mar 08 2010 9:58pm |
well had a look this evening and found that the rear sensor which had a small dent in it is the faulty one (it doesnt click when in reverse) only bad thing is that its second from the end so it looks like im going to have to take the rear bumper off.
Mon Mar 08 2010 10:31pm |
svan112 Member Since: 13 Dec 2009 Location: Across the Baltic Posts: 10 |
Mine seem to play a trick every now and then but it seems to be weather related some how. The more moist/wet outside and cold the more inaccurate they seem.
Wed Mar 10 2010 9:02pm |
